Rev limiter as shift indicator?
Old Nov 11, 2007 | 04:26 PM
Jim in Tucson's Avatar
For spirited street driving, are there any issues with using the rev limiter as a shift indicator? I've set the rev limit to 7K rpm and that's where I shift.
Old Nov 11, 2007 | 04:31 PM
SlowSportSedan's Avatar
yea big problem....
go ahead and log bouncing that and youll see a 20+ knock....
you should rely on feel for shifting not a certain rpm
Old Nov 11, 2007 | 04:32 PM
Evo_Jay's Avatar
You should leave your rev limiter at the stock value. You should not "bounce" of it to know when to shift.
Old Nov 11, 2007 | 04:47 PM
I have data logged it numerious times. I see no further ill effects than the stationary rev limit, which I've also logged. Please explain. Thanks.
Old Nov 11, 2007 | 04:54 PM
Evo_Jay's Avatar
Originally Posted by Jim in Tucson
I have data logged it numerious times. I see now further ill effects than the stationary rev limit, which I've also logged. Please explain. Thanks.
Ok do it. I just know I wouldnt.
Old Nov 11, 2007 | 04:56 PM
Boltz.'s Avatar
FCOTM Winner
I just don't see why you wouldn't just shift when it feels like 7k? You won't hurt the car going a little higher or lower. I have no clue why anyone would lower their rev limit from factory, does it make the car feel safer to drive??
Old Nov 11, 2007 | 05:52 PM
ONRAILS's Avatar
I know drag racing you will murder your ET hitting the revlimiter at all.
I prolly have a GIG of logs. When i'm sideways i'm on the 8K revlimit of my 2.3 quite a bit. (i'm sideways a lot)
and it doesn't knock. Neither does my 5250 2step.
Old Nov 11, 2007 | 05:53 PM
20Grockit's Avatar
+1
ONRAILS's Avatar
also i found if i stand on the gas from idle and then hit the 2step it will knock, however if ease into it while staging then first yellow light floor it. No knock will be present.
Old Nov 11, 2007 | 05:56 PM
20Grockit's Avatar
+1 on that
Old Nov 11, 2007 | 07:06 PM
Okayyyyyyyyyyy...
Then will someone please explain how the NLTS mod works? I assume it is on the same technique as the stationary or max rev limiter. Is the NLTS mod also considered a no-no?
I thought all the tops drag EVOs running AEM boxes were using NLTS. Isn't that a rev limiter functionality as well?
Old Nov 11, 2007 | 07:19 PM
Evo_Jay's Avatar
yes. NLTS is good. Its just not good to use a rev limiter as a shift indicator.
Old Nov 11, 2007 | 07:34 PM
garryfieldevo's Avatar
not only is it a high knock count you'll find that you tend to drop p[ower a bit before redline, might be best to shift when that peak pwoer died out
dragon831
Nov 12, 2012 08:02 AM
marcouxa1
Lancer Engine Management / Tuning Forums
Jun 5, 2012 01:07 PM
Ariful
Sep 22, 2008 05:55 PM
DANMEND
Evo X How Tos / Installations
Aug 5, 2008 05:16 AM
Turbotoyzz
15
Jan 9, 2007 06:48 AM
