cobb EVO access port
Old Nov 19, 2007 | 05:43 AM
dsmdeliveryboy's Avatar
So im looking to get the cobb access port and was wondering if anyone has used it on there car...my friends have them for there wrx's and noticed pretty good power gains from it so im wondering if it will do the same. right now my car has hks 264/272 cams, hks catback(soon to be turboback), upper and lower intercooler piping, hks bov, intake, 750cc injectors, wally 255, clutch and flywheel, stock turbo, and im pretty sure thats all of it.
Old Nov 19, 2007 | 05:54 AM
TeStUdO's Avatar
https://www.evolutionm.net/forums/fo...play.php?f=179
Look through this forum, and don't waste your time/money with access port.
Old Nov 19, 2007 | 06:04 AM
What should i go with than? im fairly new to evo stuff and im coming from the dsm community so i have yet to learn whats out there as far and ecu reflashes etc.
Old Nov 19, 2007 | 06:18 AM
rcheung's Avatar
Your best bet is a custom dyno tune from one of the many wonderful tuners we have on this board who are also in the vendors section. Also some tuners offer a mail in flash which you can load into your ecu after you send them your original one. For that though you will need a tactrix cable.
Old Nov 19, 2007 | 06:24 AM
Evo8Emperor's Avatar
First check out tunertools.com here you can buy a tactrix cable to that plugs into your OBD-II port in the car. Then from there go to open ecu and there you can down load ECU flash. With that program and cable you'll be able to pull your current ROM on your ECU.
This will enable you to either send it out and have it e-flashed via email or if you spend the money on a wide band and get a logger which uses the tactrix cable also you can log your car doing WOT pulls in 3rd or 4th. From there if you read up on tuning in ECU Flash area you'll be able to adjust any area of the stock ecu with ECU Flash and write it back to your ecu and you flashed your car.
Hope this may help a little. Its better than spending 700 on the COBB when you can get all the help you need here and really the only thing you need to buy is the 85$ cable. Good investment if you decide to go with the universal for Subies also and you can help your friends out too.
Old Nov 19, 2007 | 06:57 AM
Pr3z's Avatar
Don't waste your money on the cobb, it's completely worthless for the money.
Old Nov 19, 2007 | 07:22 AM
iturregui's Avatar
What he said!
Old Nov 19, 2007 | 07:28 AM
tvor's Avatar
A little bit of bias in this thread. Read through here, there's a discussion on this topic: https://www.evolutionm.net/forums/sh...d.php?t=299786
It's all in what you want. I got the AP recently because I like that it's a small package and I will be able to do my own tuning or get it tuned by a shop very shortly. There's pro's and con's to both routes. With the AP you have a company that is dedicated to supporting the product and releasing maps/troubleshooting. Using ECUFlash you have the community to help you out there. All in what you want.
Old Nov 19, 2007 | 07:53 PM
it looks like the cobb tuner made pretty good numbers and i dont really care about spending $700 cause im not paying for it lol
Old Nov 19, 2007 | 07:57 PM
and i dont understand how the tunertools thing works
Old Nov 19, 2007 | 09:21 PM
bump
Old Nov 19, 2007 | 10:30 PM
nightwalker's Avatar
waste
Old Nov 20, 2007 | 05:22 AM
mchuang's Avatar
First off Community > Company lol
No but on the realz the only way the cobb access port would be worth the money is if they some how are able to incorporate an option to switch to speed density on stock ecu, other than that it really has no advantage over ecuflash and that advantage will be out the window pretty soon.
Old Nov 20, 2007 | 06:14 AM
sp how much is it to access that website to get the maps?
Old Nov 20, 2007 | 06:21 AM
You can dl maps but they really wont be any good for anyones car but the one they came from. They may be alright but there still going to need to be re-tuned to your car. Open Ecu and Aktive Matrix are both free you just need to register.
