Problem Clocking Turbo
Old Nov 19, 2007 | 02:45 PM
Chereck04's Avatar
Hello. I'm having trouble getting the center section of my garrett gt3067r to rotate. The intake side will rotate easily, however the exhaust side is seized. There is no shaft play, and the compressor rotates freely, so IDK what the problem is. I tried soaking it in PB blaster for several hours, no luck. I also tried moving it with some really big channel lock's and then lightly rapping on it with a brass hammer, still nothing.
If anyone has any ideas on what I can do, please share them. If worse comes to worse I'm going to have to have it shipped out and serviced I guess. Any input would be helpful!
Thanks, Ken
Old Nov 19, 2007 | 03:01 PM
9sec9's Avatar
Not sure about the 3076, but make sure it's not 'pinned' to a fixed location. If it is, you may have to drill another hole in it's new location. Also, when you clock it, make sure you don't go so far as to affect the oiling, either incoming or draining. You can usually get away with a small amount of clocking.
Old Nov 19, 2007 | 03:08 PM
JKav's Avatar
30Rs are not pinned.
Sometimes they get crusted on there. Make sure the PB is soaking into where the turbine housing meets the center housing.
Keep rapping the turbine housing with a deadblow hammer (not brass) til it pops free. Then you can re-clock however you like.
Old Nov 19, 2007 | 03:55 PM
Full Function's Avatar
+1, I had the same problem here before, they just take some extra "love" when they don't budge.
Jerry
Old Nov 19, 2007 | 05:10 PM
Chereck04's Avatar
Thanks guys, I appreciate the quick reply.
I will switch hammers and give her another try in the morning. I was getting frustrated so it was time to call it for the day. I'll let you know how it turns out, thanks again!
Old Nov 19, 2007 | 05:30 PM
Make sure you spray a good amount of the PB Blast back on before you call it quites for tonight so it can soak over night.
Jerry
Old Nov 20, 2007 | 11:16 AM
Chereck04's Avatar
Problem Solved!
I gently persuaded it with a rubber mallet this morning. I'm sure letting it soak overnight in pb blaster helped too. Came off with 3 light hits, now i'm good to go.
Thanks again guys, I appreciate it.
Old Nov 20, 2007 | 12:02 PM
Problem Solved!
Glad it worked out for you...
Jerry
Old Nov 20, 2007 | 12:18 PM
SmokinU's Avatar
Yeah typically the housings get carboned up and stick to the center section. Easy way is also to heat it with a torch a little and that usually allows the housing to swell a little and then pop right off. Glad you got that apart though...
Old Feb 17, 2008 | 07:27 AM
zbomb's Avatar
How far is too far? I'm putting my new 35R on and the compressor outlet is hitting the block.
Old Feb 17, 2008 | 08:21 AM
PVD04's Avatar
You can adjust your compressor housing as much as you'd like. The important part is the center cartridge; make sure the oil drain is on the bottom.
-Paul
Old Feb 17, 2008 | 08:28 AM
zbomb's Avatar
Thanks Paul.
asu11
Sep 22, 2016 08:20 AM
golgo13
27
May 11, 2010 04:32 PM
mattgood2
16
Jul 28, 2009 02:24 PM
Amante
18
May 22, 2008 04:26 PM
_EVOlved_
May 1, 2007 08:36 AM
