Precision turbo clocking
Old Sep 19, 2016 | 02:14 AM
asu11's Avatar
I am in the process of clocking my turbo to fit my new setup and had some questions since I have not done it before. Turbo is a gen2 6266.
I am able to rotate the exhaust housing side no problem, but to spin the compressor side I could not just loosen the bolts and rotate it.
It seems the o-ring inside is providing a tight seal. I also did not want to damage the o-ring in the process. I ended up removing the compressor side completely.
Is there any special way to install it back on or do you just be careful not to mess up the wheel and bolt it back on?
Are both sides are able to be rotated 360 degrees?
Obviously I have my drain facing straight down and feed facing straight up.
Old Sep 19, 2016 | 09:54 AM
LetsGetThisDone's Avatar
You can clock them however needed. I would lube the oring with some Vaseline, should make it easier.
Old Sep 19, 2016 | 10:23 AM
RalliartRsX's Avatar
Apart from the drain facing down/feed facing up (or within 10 degrees of the vertical), you can clock it whichever way fits best.
Old Sep 19, 2016 | 12:13 PM
That's kind of the point of clocking it. So the turbine inlet and compressor outlet are pointed where you need them, and the CHRA is properly oriented...lol
Old Sep 19, 2016 | 12:50 PM
Wait, clocking doesn't mean knocking someone the hell out?!?!?
I had it wrong all along.........
Old Sep 22, 2016 | 12:27 AM
Teal2nnr's Avatar
I like how it says "newbie" under your forum name, yet you have one of the oldest join dates I've seen. Lol.
Old Sep 22, 2016 | 08:20 AM
I think post count determines that title. lol
JDMevoBOOST
16
Oct 9, 2011 11:18 PM
SlowEvo-IX
17
Dec 1, 2008 02:25 AM
Chereck04
11
Feb 17, 2008 08:28 AM
HPF Kyle
Jan 4, 2007 07:51 AM
