Burning clutch smell and oil leak
Hello,
I attended an auto-x yesterday after putting approximately 2000 miles on my new Competition Clutch (stage 2) and after each run my clutch was burning really bad ( the smell was very strong). This also happened a few days before the event but it happened when I was trying to put my car up on ramps and I figured I had just slipped the clutch too much when pulling up on the ramps. However, after the auto-x I figured I had better figure out what's going on before my new clutch is worthless (if it's not already, that is). I do want to point out that it is not slipping at all at this time and I did several highway pulls at full throttle in 4th, and even in 5th, to just to make sure and it did not slip.
So fast forward to today, I jacked up the car and found a decent amount of oil, I think, coming from between the block and the transmission / bellhousing. When I replaced the clutch, I also had the flywheel resurfaced, and I inspected the rear main seal and it did not appear to be leaking. So I didn't replace it. That now appears to be a mistake. Please see the pictures below and let me know if you think I need to remove the transmission and inspect / replace the rear main seal.
Also, just as an aside, I have bled the slave cylinder and made sure all the transmission to engine bolts were tight. There were no issues with either the bolts (no missing bolts and both dowel pins were present when installing the transmission as well) or air in the hydraulic clutch system.
Again, if anyone has experienced very strong smell (and some smoke) coming from the clutch, but no slippage, with a low mile clutch and has any advice, I would really appreciate it.
Thank you.
Pics:
And here is a picture of a different part of the oil pan, the rest of the undercarriage is this dry:
Thanks again!
Thank you.
Pics:
Thanks again!
Well, interestingly enough, I did attempt to replace the trans input shaft seal, and it was very difficult to get it to seat. I did the best I could, but it is very possible that it's not seated in all the way / correctly. That's the round, thick, seal that goes around the input shaft from the transmission into the clutch assembly, yes?
Oh, an thank you for your reply.
EDIT: I was actually thinking of the seal on the shaft from the transfer case to the transmission.
I suck with oil leaks but have you confirmed its engine oil not gear oil? If oil was getting on your clutch disc the clutch would slip in high load situations like WOT 3rd gear for example. The two might be mutually exclusive.
As far as the clutch smell is concerned, I hate to say it but you might wanna work on your technique at the starts. If you slip it too much its going to stink.
That seal on the case is no joke to replace. However, you would be leaking tcase fluid into the trans if that were leaking, you would not be getting fluid leaks externally. Did you make sure both orings were installed on the tcase prior to installing it on the trans? There is the big one that goes around where that seal is, and then there is a little tiny one that seals an oil galley.
I'm not sure what to do at this point. I've contacted a few local shops and am getting quotes on removing the transmission to determine where the leaks are coming from. Does that sound like right thing to do at this point?
Thanks
If you did yourself before, do it your self again. But yes, you need to determine the oil leak, it's causing the clutch to slip. At this point you should probably throw a new clutch disk in, it is likely soaked with oil and ruined.
I'm no car genius but if I see a puddle under a car I can dip my finger and bringing the odor to my nose, tell if it is engine oil, transmission oil, antifreeze, hydraulic fluid, A/C water, brake fluid or if a dog has peed on the car. Knowing what fluid is the first step in tracking down the source. Bad doggie.
evo9powerr
12
Dec 31, 2014 05:41 AM
mikemike396
Mar 8, 2013 08:51 AM
Raceghost
21
Nov 2, 2012 07:47 AM
kmcconn9
Feb 26, 2009 11:56 AM
