is it a 20G wheel? or a Green wheel?
TD05, TD05H, TD05HR, TD06, TD07, etc refers to the turbine wheel.
The early Green turbo were a 20G-TD05HR and they clipped the TD05HR turbine wheel so it would flow a bit better to help match the extra compressor flow.
The Green 20GLT (LT = "large turbine") no longer uses the TD05HR turbine wheel they change to the larger 11 blade TD06SL2R turbine wheel.
You are a bit mixed up here, 16G, 18G, 20G, etc refers the the compressor wheel only.
There wasn't ever an "early Green" turbo. It started off with the "20g-8" which was a TD05HR turbine with a 20g reverse compressor wheel in the Evo 8 compressor housing. Next came the "20g-9" which was the same turbo with the 9 compressor housing. Around the same time as those turbos, FP brought out the White Rabbit, which was a TME turbo with the 5-blade compressor wheel currently found in the 20g-9-5 and Green. Buschur started using this wheel in his 20g, which is where the 20g-9-5 came from. They then put a slightly larger turbine on the turbo and called it the Green or 20g-lt. In reality, it is not a 20g at all. It is a custom compressor wheel and a custom turbine wheel in the evo 9 compressor housing and TD05 turbine housing.
-Paul
I realized after I posted that I was referring to compressor wheels.
-Paul
-Paul
Yes the 5 blade compressor wheel is a custom but the turbine used in the Green is a TD06SL2R.
I also have 18psi wg and the pipe connecting to the compressor outlet. My boy needed his motor built and was in need of some cash. This will probably buy him a set of rods or pistons.
The turbo does need a rebuild however. Calling FP on Monday!
See my for sale thread here:
https://www.evolutionm.net/forums/sh...d.php?t=359823
clip14
Aug 3, 2016 04:46 AM
racer135
10
May 14, 2009 07:50 AM
