bov problems????hepl!!
Old Nov 26, 2007 | 08:43 AM
dino21's Avatar
i heard that,if you evo is stock without any ECU upgrage the blow off ventil doesent work properly.is it true?i really would like to have that sound swoosh,and i dont want to buy some bad bov for my car.
Old Nov 26, 2007 | 08:54 AM
Smike's Avatar
Please search and read - this has been covered 10^23rd.
Do not VTA - period (unless you go to a MAP setup).
Get a cone filter. You do not need a new BOV, the IX metal one is great as is. "Problem" solved.
Old Nov 26, 2007 | 08:55 AM
dubbleugly01's Avatar
this is true, since the car is MAF equipped, any venting you do to the atmosphere is going to make the car run poorly. You'll need an ECU upgrade as well as convert the car to speed/density instead of MAF.
Old Nov 26, 2007 | 09:07 AM
dino21's Avatar
ok thanks,a lot i will look again,but i was trying but could find it.
thanks again.
Old Nov 26, 2007 | 06:07 PM
lurkerpika's Avatar
thanks again.
lol somehow i think hes lying....
Old Nov 27, 2007 | 12:11 PM
v8hater's Avatar
if you want to hear the swoosh sound just upgrade your intake. Keep you metal IX BOV its the best BOV on the marke imo
Old Dec 11, 2007 | 05:20 PM
EvoChe01's Avatar
now can the IX bov be put on an XIII and handle more boost like 24 or more lbs
Old Dec 30, 2007 | 08:58 PM
vetboss's Avatar
As far as I know, the IX stcck BOV will work on the VIII,...I am running a turbosmart dual port BOV that I salvaged from my VIII and mounted on my IX with no issues at all. I am also running 21 lbs solid on this BOV without a hitch. For what it is worth, the shop evo (Corey's) at atlantic motor sports in Gaithersburg was running this same BOV at somthing like 27+pounds with no issues, leaking, etc. If you want the swoosh, just get a dual port and be done with it. I have not noticed any driveablility issues with the aftermarker BOV, aside from an occasional lag into first gear when peddling the gas and clutch (will need more gas, higher rev to maintain itself. Good luck....
Old Mar 31, 2008 | 05:02 PM
dino21's Avatar
i have a dual port bov mounted couple days ago and its great,,,works properly and the sound is great tooo..finallly
thanks guys
Old Mar 31, 2008 | 09:31 PM
EvoXstylin's Avatar
what a way to bring back your thread from the dead haha. had to comment on it..
Old Apr 3, 2008 | 03:40 PM
dino21's Avatar
hahhaa i didnt think about it
Old May 24, 2008 | 11:52 AM
RAZOREXPRESS's Avatar
how is your bov adjusted?Because i installed the same one and it dosent hold boost correctly. I'm supposed to be spikeing at 22-and holding 19psi. Only in 5th gear from about 70mph just accerating slowly,then it will hold 19.But not in any other gear. Ive seached all over and have found nothing.Someone please help.
Old May 24, 2008 | 02:39 PM
help
EvoXXX:)
Mar 25, 2016 11:00 AM
04forcefed
Oct 16, 2014 06:31 PM
oscarquinones
Aug 5, 2013 02:58 PM
shadow1
Jul 3, 2010 10:46 AM
evodave
10
Feb 12, 2005 07:16 PM
