Miss firing in multiple cyclinders
Old Nov 27, 2007 | 10:27 AM
DC2toEVO8's Avatar
My engine light came on when i banged on 5th, on my 03 evo i used a diagnose tool to read the code and it was miss firing in multiple, i changed my spark plugs and check my coil packs, my buddy said it could be from a boost leak to etc. but recently the engine light went off and came back on? i mean can it be my tune? or what? help i bet this happened to alot of you... just a little help
Old Nov 27, 2007 | 10:28 AM
TeStUdO's Avatar
If you are getting the P0300 code its very common and happens to alot of us.
Old Nov 27, 2007 | 10:52 AM
smp3000's Avatar
I just read My CEL yesterday and expected to Just see the P0420 (no cat) code, but a P0300 snuck in there. I'm not too worried about it as I've cleard the codes and it hasn't come back with about 100 miles on the car since.
Old Nov 27, 2007 | 10:59 AM
[Neo]'s Avatar
Im on my 4th Check engine light first 2 were miss fire & the other a no cat. Im on a CEL now with the same problem 5th gear lag. I bet its just the miss fire again.
Old Nov 27, 2007 | 11:16 AM
waitin4d's Avatar
Just get a creader and live with it. It won't be gone until you rebuild the tranny.
That's what I do.
Old Nov 27, 2007 | 11:28 AM
deadbeatrec's Avatar
That's what I do.
creader didnt do **** for me. its a piece of crap, wouldnt even read my codes
listen, if its the P0300 u are going to have to deal with it. mine comes and goes every 3 weeks or so. its nothing to worry about.
Old Nov 27, 2007 | 12:35 PM
CrackerJackToy's Avatar
Its just going to happen man. I just got cams & had the same code come on twice in 2 weeks. I just clear it, no biggie. I notice no misfire at all myself.
Old Nov 27, 2007 | 03:59 PM
DC2toEVO8's Avatar
wow so s@#t just happens hahaha, damn whew i was going to pay someone to give me a boost leak test and etc.. man X_X so i should just live with it ha dang
Old Nov 28, 2007 | 12:58 PM
DC2toEVO8's Avatar
sorry to be a bother but the engine lights been on now the thing is that seems like a huge lag on 5th gear!?#@ im worried should i be? i mean it drives fine.. tho weathers cold outside so i spool very quick..
Old Nov 28, 2007 | 01:53 PM
theblue's Avatar
probably not a boost leak (but you still might have one).
you did plugs, that would be my first guess.
my second guess is a bad tank of gas.
Old Nov 28, 2007 | 06:48 PM
DC2toEVO8's Avatar
clean that out with some stuff my bud give me i forgot whats it call.. filled it up full and put that stuff in damn it i cant think of whats it called. engine cleaner basically. and gas from shell.
Old Nov 28, 2007 | 06:54 PM
wizzo 8's Avatar
Is it always the same cyls? Is the plug gaps right?
Old Nov 28, 2007 | 07:08 PM
ONRAILS's Avatar
what?
dude you changed your coilpacks and plugs without the car running funny? just for a damn light?
Old Nov 28, 2007 | 07:16 PM
C6C6CH3vo's Avatar
0300 can be caused by a list of things. First of all start with the basic crap, what did you gap it to and with what kind of tool?
A boost leak may cause a "too rich" code instead.
Old Nov 28, 2007 | 07:45 PM
DC2toEVO8's Avatar
the gapping tool, all of them gap to spec. 26mm. at first when i didnt gap them my spark plugs would blow out once i hit 20psi of boost, after i gapped it i can go full boost. no problem just 5th gear is a bit of a lag....
