MR owners question!
Old Dec 1, 2007 | 12:36 PM
itzcharlez's Avatar
MR owners question!
hey my fellow MR owners....
since you all have the 6-speeed...
what clutches are you all running?
and what kind of proples are you guys getting in to?
currently have 350whp on stock clutch...
need something that wont destroy my tranny...
dont plan on launching much...
doubt i'll ever track it...
just need it for daily driveee
Old Dec 1, 2007 | 12:44 PM
Canexican's Avatar
I have the ACT HDSS street clutch. Its stronger than stock, pedal pressure is slightly heavier than stock, engagement is good and have had no problems. I'm not modded yet, so I can't tell you how well it performs with 350whp, but I do know its got quite a bit more clamping power than stock. There are alot of people that run this clutch and should be fine if you are not launching or racing all the time. Probably the least expensive quality clutch kit as well.
Old Dec 1, 2007 | 01:14 PM
chaotichoax's Avatar
I run the ACT HDSS clutch also...I'm at the same power level as you
I've had the clutch for about 12k miles and can't complain
get buschur shifter bushing though...prior to having these bushing I'd get lock out of forth gear at high rpm...bushing resolved this
Old Dec 1, 2007 | 01:24 PM
cssaddictm4's Avatar
Had the HDSS, didn't know the clutch disc was toast (apparently melted to flywheel), and destroyed 6spd. If getting an ACT clutch I would recommend either stock or ACT flywheel. I had the clutch with an Unorthodox flywheel and it would rub (noticed unusual wear at disassembly) which would cause the car to roll in 2step.
Old Dec 1, 2007 | 03:04 PM
timmiii's Avatar
Stock clutch seems fine.
Old Dec 2, 2007 | 12:05 AM
itzcharlez's Avatar
what do you mean ? please explain further..
so you have a problem with the HDSS becuase of the HDSS? or becuase of the flywheel?
Old Dec 2, 2007 | 12:11 AM
DR EVO_38's Avatar
I am picking my ACT clutch and flywheel tomorrow. really good price for both. PM me for more info. I am getting HDSS clutch and Pro lite flywheel. i will have installed on Friday
Old Dec 2, 2007 | 01:00 AM
timmiii's Avatar
I think you should get a tilton carbon carbon or maybe a ATS. I think those will hold the power just fine. =]
Old Dec 2, 2007 | 06:23 AM
deepee1's Avatar
stock here. installed ACT HDSS @ 21k (with SS Clutch Line) - now at 23k... There's a lot of bad experiences on this forum with the ACT kit, but I've had no problem whatsoever. Running strong. (Stock flywheel).
Old Dec 2, 2007 | 08:11 AM
timmiii's Avatar
YEAHHH ACT!!! Stupid tranny...
Get the Xtreme if you want a quiet clutch that'll hold MAD power, you also need a workout...
pistons4550
Apr 16, 2015 08:25 AM
dennass69
Northwest Region
19
Oct 26, 2011 09:56 PM
68wsteve
Nov 28, 2010 03:37 PM
xSTonex
31
Apr 2, 2009 10:57 PM
EvoDom
33
Mar 5, 2009 04:12 PM
