Exhaust manifold nuts
Old Dec 7, 2007 | 04:56 PM
stryfetew's Avatar
I'm having a problem with the nuts keep backing out, what would be the best way to fix it.
Old Dec 7, 2007 | 04:57 PM
TURBevO8's Avatar
were they torqued properly? Did you forget to put the washers behind them?
Old Dec 7, 2007 | 05:09 PM
stryfetew's Avatar
From what I know it was when the aftermarket manifold was installed BUT I'm swaping it soon. SO would t his be a goodt ime to replace the nuts with locking nuts or can I just reuse the factory ones?
Old Dec 8, 2007 | 07:55 AM
KenMasters's Avatar
double nut them------------------solved
Old Dec 8, 2007 | 08:04 AM
suekie's Avatar
use some locking washers against the manifold. Will help to evenly distribute pressure on the manifold and will assist in keeping the nuts on. I would get some better quality nuts to replace the probably rusty old ones.
Old Dec 8, 2007 | 08:18 AM
stryfetew's Avatar
Yeah I'm having a tough time with taking it all out now. I'll replace all the rusted nuts with some grade nuts and lock washers
Old Dec 8, 2007 | 08:29 AM
Q@EvoPowerMods's Avatar
Dont overtorque them! Get you the online manual(search the forum, its available for free) to see what the specs are to porperly torque them down. And also get some high temp anti sieze.
Old Dec 8, 2007 | 10:20 AM
stryfetew's Avatar
I already got it printed waiting on me to re-install Just having a ***** of a time sperating the hotside from the CHRA. Any hints?
Old Dec 8, 2007 | 10:53 AM
MajorPayne's Avatar
you could also try copper exhaust nuts...they have worked well for me
Old Dec 8, 2007 | 11:59 AM
stryfetew's Avatar
Where would I find such things?
Old Dec 8, 2007 | 12:35 PM
piranha's Avatar
I used these guys lock nuts on my RX-7... Worked very well. http://www.atpturbo.com/Merchant2/me...egory_Code=FST
Old Dec 8, 2007 | 03:59 PM
RevMoto's Avatar
Just sounds like you aren't torquing them enough. Also if you want use some loctite.
Old Dec 9, 2007 | 07:49 AM
stryfetew's Avatar
I got another question. How are you supposed to torque the nuts you can't physically get to with a torque wrench And I've read also to start from the inside out, but the FSM says do it from outside in?
Acuality
For Sale - Wheels / Tires
Aug 17, 2016 04:19 PM
Ude Lose
Oct 6, 2015 08:04 AM
cleudson
Oct 4, 2013 07:47 AM
Xtremist
14
Aug 6, 2010 01:55 PM
TS8
11
Jul 19, 2010 11:34 AM
