what the freakin heck is goin' on!
Old Dec 22, 2007 | 09:47 AM
j14mp's Avatar
I put my TBE on.... I don't have any other mods and I understand the car HAS to have a flash (flash, fuel pump and drop in coming soon) It's winter, I don't see myself buying mods in the freaking winter....
I put the exhaust on "just because...." long boring day and had nothing else to do. Wasn't looking to get power, just basically looking at fitment BUT I COULDN'T GET THE STOCKER BACK ON AFTER!!!! I have to put rust inhibitor and all kinds of other junk on it first but I realllllyyy didn't want to have to go through the process of having to switch the TBE back on in the spring so I'm just leaving it haha
Now I don't get on it toooooo much anyways seeing as I'll be using it for track days next year. I do a third gear pull onto the highway here and there just to see how the cars doing (I have an e-01 with the EBC not hooked up) Basically, I just read the boost to see whats up. I'll do like a couple pulls a week and everytime I do a pull it gets sloowwweeerrr and sloowweeerrr and slooweeerrr.... I spike 23.5 (BAD!!) drop to 15 psi and it holds around that area! I did a leak test and all and theres NO LEAKS! what the frick is my frickin car doing?? is it just in desperate need of a flash?? lol It doesn't pull hard to redline at allllllllllllllllllll
2003 evo 8 with TBE and thats it......
Old Dec 22, 2007 | 09:53 AM
apagan01's Avatar
how did you conduct the leak test ?
Old Dec 22, 2007 | 09:59 AM
j14mp's Avatar
air compressor and watched the gauge and listened for any leaks... Someone I know has a smoke machine type thing... do those work???
It def holds boost... I'm beginning to think maybe its the ECU??? I mean the TBE has been on for a little while... maybe if I reset the battery?
I am spiking 23.5 psi on a bone stock evo soooooooo I don't know....
maybe I should do another leak test but I mean it gets worse and worse, I don't want to be running a half *** car next year ya know? Maybe a flash will solve it but I just don't know. It's probably even dangerous to drive the car with a TBE and no flash huh?
Old Dec 22, 2007 | 10:06 AM
badhabit90's Avatar
is that ALL you have done?? you say you have and e-01. is it connected to the car?? or just installed and not being used??
knock may be pulling your timing. did you reset the ECU after your modification?? sometimes it doesnt understand the extra "flow" from the exhaust and will take awhile for the ecu to relearn the fuel curve naturally. disconnecting the battery and waiting about 10 minutes will usually help.
Old Dec 22, 2007 | 10:18 AM
j14mp's Avatar
yea the e-01 is being used strictly as a boost gauge for now.. not hooked up as a boost controller...
See I definatly knew it was something along those lines because it makes perfect sense. I just always need a second opnion before I just start assuming things but that defiantly helps a lot thanks!
I am going to give this a shot.. any other ideas guys would be great too
Old Dec 22, 2007 | 10:23 AM
eponti's Avatar
23 psi is high for un tuned evo specially if you are using 91oct.So more than likely its knocking and pulling timing up top.
Old Dec 22, 2007 | 10:45 AM
j14mp's Avatar
im running 93 and yea it DEF really high.... it was about 30 degrees outside so that doesn't help but I'm still running stock boost... just spiking retardedly high. at redline, I'm at about 15 psi holding so whooo knowsss
Old Dec 22, 2007 | 11:01 AM
badhabit90's Avatar
Cool
you said your using the e-01 as a boost gauge, where are you connected to?? sounds like your stuck on wastegate pressure now. hmmm....
Old Dec 22, 2007 | 11:08 AM
j14mp's Avatar
some people connect it to the fuel pressure regulator... I avoided that and attached it to a vac line near by on the intake manifold
98autogstspyder
657
Apr 27, 2022 01:48 PM
13-0
154
Aug 16, 2015 12:57 AM
blk2gdsm
18
Jan 25, 2012 09:02 AM
Methodical4u
44
Jan 29, 2010 07:58 PM
Blitz
72
Aug 4, 2008 01:17 AM
