WHAT'S THIS?! HTA35r is off the car??
Old Dec 27, 2007 | 05:06 PM
  #61
evolved83's Avatar
i am liking the manifold
Old Dec 27, 2007 | 05:16 PM
  #62
evovin's Avatar
Are the runners longer than Shearer's, Full Race or AMS
Are you going to sell this header in the future or just for your own car?
Old Dec 27, 2007 | 05:35 PM
  #63
David Buschur's Avatar
We had almost the entire kit on the car today.......almost. The header as you see it was bolted on tight, finished the downpipe. Put the wastegate on, it's sweet how it is set up.
The turbo is pretty low but not so low as the drain for the turbo won't work. I do have to get some fittings for it though.
The lower i/c pipe is the worste part and I didn't finish it. I wanted to get the header over to the machine shop for milling before the end of today.
I am HOPING the header is finished being milled tomorrow. If so I'll finish the wastegate dump tube and lower i/c pipe.
I am waiting on my brother to come back from his vacation this week (spending the week out at my house hunting). When he comes back I'll have him swap out this head gasket and then the car will be ready for the dyno.
The inlet to the Tial housing is VERY small comparing it to the Garrett housing. When you start studying it though the "throat" of the turbine housing looks identical. I am hoping it will make atleast the same power that it did before. If so I'll consider it gains as this set up is lighter than the old one.
Runners, I'm not sure if they are longer or shorter than Shearer's or the Full Race I took off. I did measure them today as I was curious how close we got 1/4 compared to 2/3. We were within 1" and that's fine with me. Hell I'd even call that equal length but don't care.
We did some flow bench testing of headers (and intakes too actually) quite a few years back. We did it when we were working heavily on my tube chassis car. We put a head on the flow bench and then spent a few days bolting headers/manifolds and tubing up to the head to see how it effected the head flow. (crazy how many things we done and tested over the years that I forget about)
Anyway, at the time we flowed the Turbonetics manifold, HKS manifold, some other odd ball header and then started putting tubing and bends up to the ports to see how they effected it. At that point I said to the guy who owns the flow bench, "Guess I'll go weld together a header." He went off on me (mildly) about how you can't just put tubes together, you have to know what you are doing etc. etc. I built the first header for the car and when it was done I took it over, had it milled and headed back to the flow bench. We put it on the same head and then put the header on, adding the header was like gaining .250 lift on the exhaust cam, which is freaking HUGE. He looks at me and says, "Well it should work, it's just a bunch of straight pipes." I got a chuckle out of it. The design was similar to what you see here except on the tube chassis car I didn't have to turn the collector down, it mounted straight out, so it was minimal bends. I don't know if Brent Rau's header is still like that or not but his (in my opinion atleast) was modeled after mine on his car.
I suppose we could sell this kit but you have to realize it is for a car with no A/C and I am running the small radiator in my car. In all honesty, I dont' have any desire to sell these. If the housing works though there will eventually be a header built to fit normal EVO's with A/C etc.
Tomorrow, if my header isn't milled, I am starting on another header, same basic design, T3 flange. I may change the location to make the rest of the job easier.
Old Dec 27, 2007 | 05:50 PM
  #64
DynoFlash's Avatar
Originally Posted by jmartinez1170
Another great product. Clean and simple.
If I had to sumarize Buschur Racing products in two words - "clean and simple" that is (oh and fast as a mother ****er)
Old Dec 27, 2007 | 05:53 PM
  #65
EvoDan2004's Avatar
who's exhaust manifold do you use on ur evo al???
Old Dec 27, 2007 | 06:02 PM
  #66
Thanks Al! Very nice.
Old Dec 27, 2007 | 06:36 PM
  #67
9sec9's Avatar
I hereby commission you to build a twin-scroll header for the 20G-LT. The workmanship and design looks excellent. Very nice David.
Old Dec 27, 2007 | 07:00 PM
  #68
steadly2004's Avatar
beautiful
Old Dec 28, 2007 | 12:34 AM
  #69
chuntington101's Avatar
David, very nice header. have you seen Norris Designs headers??? they are very similar in shape to yours. works a treat for him!
thanks Chris.
Old Dec 28, 2007 | 06:17 AM
  #70
I haven't seen ND's headers, without a small radiator this design is impossible, does he run the small radiator?
9sec9, didn't you know I've built a twin scroll header for the 20GLT? One off too, it is sitting here doing nothing, tried to sell it about a year or so ago, nobody wanted it. Daniel ran it on his car, it's ceramic coated, I relocated the turbo down about 1-2" for a better collector/runner configuration when I did it so it takes a special downpipe, which also just so happens to be sitting here. You have our phone number Might be REALLY cheap to YOU.
Old Dec 28, 2007 | 06:53 AM
  #71
scheides's Avatar
EvoM Moderator
Dave, I don't remember you mentioning this in the past; how did it do power-wise compared to the full-race manifold? Or compared to the ported stocker?
Old Dec 28, 2007 | 07:25 AM
  #72
How did what do compared to the Full Race? The one I built? I never tested it on they dyno against anything else if that is what you are talking about.
Old Dec 28, 2007 | 07:49 AM
  #73
Paul Nelson's Avatar
Manifold looks good David. Sucks about the head gasket but you put some abuse on her
Cant wait to see her back up with new #s
Old Dec 28, 2007 | 09:28 AM
  #74
Bored today..............building another header
Old Dec 28, 2007 | 09:30 AM
  #75
scorke's Avatar
Hahaha, I am so damn jealous, I wish I could head out to the garage, grab some stock and start busting stuff out.
Scorke
