boost spike in higher gears
Old Dec 26, 2007 | 09:28 PM
Rexpeed's Avatar
1st,2nd and 3rd gear the boost holds fine but in 4th and 5th the boost spikes pretty bad. Does it have anything to do with my EBC?...never had this problem before.
Thanks!
Old Dec 27, 2007 | 12:22 AM
sparky's Avatar
What turbo & what WGA. When you say spike, are you meaning creep?
Old Dec 27, 2007 | 07:16 AM
Rexpeed's Avatar
35R with Tial WG. boost just goes up...I guess its called creep
Old Dec 27, 2007 | 07:37 AM
TiALSport's Avatar
check for leaks in the line
Old Dec 27, 2007 | 07:39 AM
AlwaysinBoost's Avatar
what kind of EBC do you have? have you tried an MBC at all?
are you are the WG doesn't have any restrictions which would cause the exhaust to not be able to evacuate fast enough.
Old Dec 27, 2007 | 07:57 AM
Rexpeed's Avatar
could be a leak...never had this problem before..EBC is Blitz SBC ID3
Old Dec 27, 2007 | 08:13 AM
TiALSport's Avatar
also, take the EBC out of the situation and run on spring alone, rule out one thing at a time
Old Dec 27, 2007 | 08:38 AM
EVIL_EV0's Avatar
Its normal to see higher boost in higher gears due to higher load.
Old Dec 28, 2007 | 01:54 AM
Rexpeed's Avatar
Appreciate the help guys thanks!
Old Dec 28, 2007 | 06:52 AM
TiALSport's Avatar
not if you have proper boost control
Old Dec 28, 2007 | 04:18 PM
mudduck's Avatar
Yes, with an mbc; but with his EBC, I'd expect that to be controlled.
Old Dec 28, 2007 | 04:49 PM
scheides's Avatar
EvoM Moderator
It's prolly your EBC. Reset boost doing 4th gear pulls, then see if it is still where you want it in lower gears. I know I had this problem when I started using my GM BCS w/ stock ECU.
TOAjosh
May 22, 2012 04:55 PM
AWDTerror
Jul 28, 2009 03:13 PM
Celica2EVO
Nov 6, 2007 08:41 PM
mudduck
Jan 28, 2007 05:09 PM
Scoot
25
Sep 30, 2005 07:37 AM
