Spacer for O2 sensor...where to buy?
Looking to get a spacer for my stock O2 sensor so my check engine light stops coming on with my HKS exhaust. Anyone know where I can get one? AMS is a no go.
This is how to make a mechanical o2 fix if you have a test pipe/resonator/high flow cat, that gives a cel. You can find it on ebay for about 15 dollars shipped. But why buy it when you can make it for 3 dollars using parts from your local Pep Boys?
First of all you will need 2 spark plug anti-foulers (18mm). It is made by the HELP! brand part#42002 or 42009.
You will also need a 1/2" drill bit and drill. Or a drill bit close to that size
Drill one one the anti-foulers so that the o2 sensor can fit. I recommend using a vise grip and lube for the drill bit if you ever plan on using it again.
If it doesn't come out nice use a dremel or a file.
Put the one anti-fouler you drilled and connect it on top of the one you didn't. Now you don't have to buy a electrical fix and splice your wires.
Dont you just love evoM??? 4 minutes and you have an answer with part numbers and where to get them.
If you haven't, the you are assuming it's because of your exhaust (and it might be ) but you won't know for sure until
you know what code # it is. You have have anoter more serious problem - overboosting, lean condition.
I didn't get any codes because of my HKS exhaust alone. I only started getting a code after changing to a high flow cat.
You can usually go to any auto parts store, and they will pull the code for free. Here where I am , we go to Autozone.
All that said, if the code is a P0420 (cat efficiency) code, then it happens because the readings from the front O2 and
the rear O2 are too similar; the cat isn't doing it's job as it should be in reducing emissions.
Or go here, spend $13.99 with free shipping, and you don't have to use any tools or rig something up.
http://www.speedelement.com/index.ph...mart&Itemid=38
wtvlau
Jun 16, 2017 02:08 PM
alex3dworld
Jul 20, 2009 06:16 PM
. Maybe I should have been a bit more clear. I put my Helix downpipe, test pipe, and HKS exhaust on all at the same time. Didn't mean to imply that the cat back was the reason for the code.
