shifting blocks
Old Jan 1, 2008 | 02:48 PM
evouser12's Avatar
shifting blocks
been having a problem with shifting and i was wondering if any1 had any advice...at high rpms flooring the car it will not let me shift into the next gear...its pretty much blocking it...im still on the stock clutch/flywheel...do you think thats that problem? thanks
Old Jan 1, 2008 | 03:48 PM
c_sautter's Avatar
I have the same problem, I thought maybe its just my own fault but it seems like its been happening to a lot of people. I guess its just from the way its made.
Old Jan 1, 2008 | 04:00 PM
sikrsix's Avatar
Mine would only "block" me out if I didn't line up the synchros before take off. After I installed my lower poly motor mount I can no lift shift anytime I choose.
Old Jan 1, 2008 | 04:24 PM
GTLocke13's Avatar
Check your clutch pedal adjustment. You may not be getting full disengagement.
Old Jan 1, 2008 | 04:34 PM
Smike's Avatar
More commonly called lock out
Id start here:
http://evomoto.com/tech_info.php?tec...685f5c555483ad
Old Jan 1, 2008 | 04:41 PM
turboDan's Avatar
Your stock clutch is nearing the end of it's "useable" lifespan. You can try and "adjust" pedal height as posted above but that only seems to be a "bandaid" on the stock clutch although it works well if you have an ACT clutch.Start saving up now for a new clutch.You could also try changing the transmissing gear lube out with some fresh stuff but from my experiences with the stock clutch,what you describe is usually an indication that your stock clutch is nearing the end of it expected lifespan.
One last thing that you may also consider is when living in a cold weather climate this is a Normal occurance when vehicle and outside temp is COLD...
Old Jan 1, 2008 | 04:48 PM
c_sautter's Avatar
True, I just realized that it only happened when its cold. However, sometimes it does happen when I'm accelerating on the freeway and shifting into 5th. Hasn't happened lately though. So flushing out the old fluid and putting in new fluid could possibly be a remedy?
Old Jan 1, 2008 | 05:48 PM
kaonashi's Avatar
LOTS OF THREADS ON THIS, Gear lock out search it up you'll find TONS on it.
mklepper
Aug 17, 2016 04:33 PM
gtm_maxwell
Mitsubishi TC-SST Discussion
Jul 21, 2016 08:15 AM
yifuqiao
Oct 31, 2015 07:00 AM
CatalystIX
35
Jun 19, 2015 09:35 PM
waterlooLancer
26
May 17, 2012 08:55 AM
