Forge Dump Valve cause Engine Check Light
Old Jul 22, 2003 | 02:06 PM
gochukim's Avatar
Question Forge Dump Valve cause Engine Check Light
I installed a forge dump valve (the recirculating blow off valve) and now I'm getting a check engine light.
I have tried installing it just like the factory with the nipple facing left / reset the ECU / and then after 10 mins the check engine light comes one. Engine idles high around 1500rmp.
So I reset the ECU and reinstall it with the nipple facing up / reset the ECU / and after 5 mins check engine light comes on again. This time the idle is worse as it goes up and down between 1800 to 1200.
Then I put the orginal factory BOV back on and reset the ECU and I'm back to normal.
All using factory intake. The forge DV also makes that funny laser / fluttering sound (the one everyone comments about) on both direction of install.
Anyone else have this problem and have you resolved it??
I talked to forge and they are sending me another DV, hopefully it works.
Old Jul 22, 2003 | 02:11 PM
EVO VIII Chris's Avatar
The spring may have to much tension on it causing the valve not to open all the way? You may want to check that because if you are installing it (which is way easy) right then this is more than likely the culprit.
Old Jul 22, 2003 | 02:16 PM
timzcat's Avatar
Re: Forge Dump Valve cause Engine Check Light
Your installing the recirc valve just like stock?
This is strange cause if you get a light at idle and the idle is high you probably have a vacuum leak. I am wondering if your o-rings are leaking. Try pushing the vallve in with your hand and the put a finger over the vacuum barb to see if it holds vacuum. The forge valve is open at idle so really only the vacuum hose matters if both sides of the valve are plumbed like stock.
Old Jul 22, 2003 | 05:12 PM
gochukim's Avatar
If I hold the Dump Valve with the nipple facing upwards and blow into the side port, the air just blows right out to the vaccum hole (the nipple). the bottom side hole is blocked and when i push it in and blow through the side port the air goes to that hole and not to the top hole.
Old Jul 22, 2003 | 06:18 PM
timzcat's Avatar
O-rings are bad, so basically the valve is defective. They are sending you another, right? You can always get some o-rings from them instead if they haven't sent you a new one.
There are only three pieces to the entire thing. The body, the valve and the 2 o-rings.
Old Jul 22, 2003 | 08:44 PM
gochukim's Avatar
Thanks "timzcat"!! I'll be sure to notify Forge of this problem.
gary_06ralliart
Oct 23, 2008 02:05 PM
NocturnalEVO
Dec 24, 2006 12:28 PM
Bigjoeski05
Lancer Troubleshooting
38
Jan 25, 2006 12:53 PM
Wicked
11
Nov 24, 2004 11:29 AM
digdat
Lancer Engine Tech
Apr 1, 2004 12:43 PM
