fuel pump??
Old Jan 8, 2008 | 03:48 PM
wickedwhiteIX's Avatar
fuel pump??
when i upgrade my fuel pump to a walbro 255 do i need to get my computer flashed right away?
Old Jan 8, 2008 | 03:49 PM
moreryce's Avatar
nope
Old Jan 8, 2008 | 03:50 PM
but will it run ok or no
EvoBroMA's Avatar
no need to flash. it will run fine.
Old Jan 8, 2008 | 03:56 PM
Psquared's Avatar
It will run a bit rich...you prob won't even notice.
Old Jan 8, 2008 | 05:23 PM
Kracka's Avatar
Mine ran really rich when I installed my pump and I had a noticeable decrease in gas mileage. I'm tuned now though so all is well.
Old Jan 8, 2008 | 05:32 PM
Tarmacisback69's Avatar
evos run rich from the factory, so installing without a tune should make it run very rich.
Old Jan 8, 2008 | 05:38 PM
krazirob's Avatar
^^^ yes indeed it will. I flashed my car temporary and then tuned it after the rail and injectors swap.........
Old Jan 8, 2008 | 06:31 PM
Chemwarrior's Avatar
I had my car flashed after my BR Stage I upgrade and currently in the process of having it reflashed again because I just added a Walbro FP and PPI licp. I know it is not a complete necessity to have it reflashed after this latest addition but I wanted optimum performance and safety. There's no need in wasting unnecessary money on gas for running too rich when you don't have to and you can still maintain excellent performance.
Old Jan 8, 2008 | 06:38 PM
JDMCT9MR's Avatar
Ive had my 255 on my car for about 6K and w/o a flash with no issues.
Old Jan 8, 2008 | 08:03 PM
BOOSTEZ's Avatar
Fuel pump shouldn't make the car immediately run richer. It doesn't give anymore fuel than when you had the stock one unless the fuel system demands it. I seriously doubt that stock turbo cars with relatively low boost (20-22psi) demand more fuel from the pump.
Just my 2 cents.
-M
Old Jan 9, 2008 | 11:01 AM
sparky's Avatar
For about the same price that you'll spend getting a reflash that may not actually be justified, you can get yourself a wideband AFR gauge with logging capabilities and the Tactrix cable with Evoscan/Mitsulogger software. By logging AFR's after adding a mod you'll know whether or not the fuel table needs to be altered accordingly.
Old Jan 9, 2008 | 02:36 PM
20Grockit's Avatar
it will run richer in some cases such as mine. i got a flash and all was well after that.
Old Jan 9, 2008 | 07:10 PM
insanechief's Avatar
So theres no problems/ I have heard of people not even beeing able to keep there car running and having to trailer there car to a shop.
Old Feb 24, 2008 | 06:07 PM
sllt1776's Avatar
Just installed mine with no issues. runs rich and need to adjust it but no issues. Also, OP had a IX and the Walbro is only slight higher flowing. Not as big of a difference as when install on an VIII.
EVOXMR10
Jul 15, 2012 12:22 PM
blue devil
Mar 17, 2012 07:19 AM
showoff3civic
Evo X How Tos / Installations
Jan 23, 2012 01:14 PM
gbmoto313
Aug 16, 2007 10:45 AM
k270kmh
Aug 11, 2007 03:23 AM
