Trace amounts of oil in the airbox? :(
Old Jan 9, 2008 | 12:20 PM
Mag00n's Avatar
I was checking my air filter today and when i pulled the filter out there were trace amounts of oil on the bottom of the assembly. There was no significant build up but if you ran your finger along the inside it would be covered with a layer of oil....There was no oil on the actual filter
I pulled the charge pipes and theres no oil in the charge pipes, how concerned should i be about this?
The car spools up quick and doesnt blow smoke out the exhaust, but im still concerned...
Old Jan 9, 2008 | 12:23 PM
scoob2evo's Avatar
see the tube from the top of the head to your intake? Theres the culpret... go to the DIY section and make yourself a Oil Catch Can or go buy one
Good luck!
Old Jan 9, 2008 | 12:25 PM
MRJEVO's Avatar
Do you have alot of miles on the car? Definitely sounds like blow-by.
Old Jan 9, 2008 | 12:31 PM
Mag00n's Avatar
thanks for the quick replies, ill definately check out the catch can, that makes sense.
The car has 34k on it.
Old Jan 9, 2008 | 01:25 PM
Kracka's Avatar
Crankcase breather.
Old Jan 11, 2008 | 10:11 AM
lords3t's Avatar
http://www.saikoumichi.com/product_line.html
Alchem1st
Apr 20, 2016 12:42 PM
viprez586
Jul 27, 2014 11:16 AM
otter
Jan 5, 2010 11:17 PM
rodman
May 4, 2008 09:42 AM
Evilution
May 12, 2003 02:00 PM
