Getting A Green
Old Jan 10, 2008 | 12:01 AM
  #46
Bonestock!'s Avatar
If I had a IX I wouldnt consider anything smaller than a 50trim as a turbo upgrade. But thats just my opinion.
Old Jan 10, 2008 | 12:51 AM
  #47
EVO8URV8's Avatar
Originally Posted by 9sec9
The 30R, like full-races will make more power. Depends on your goals. If you drag race, what is your goal. If you don't and want to keep reasonably close to stock response, the Green would probably be the largest currently available turbo. A Twin-scroll 30R is in the test stages, so check the thread on that if you're looking for a potential of 550 whp, but at the expense of probably a 400-500 rpm's of spool time.
A well built stock turbo with top tune or one of the mentioned turbos is not going to dissapoint you.
I drag race whenever the tracks opens here. U sure can read my mind when I'm looking for (at least) 500whp (on 91 with meth though)
The twin-scroll 30R is nice to have but thats way out of my budget. The biggest I would probably go is the HTA 35r. The 3065 isn't too bad, so is the Green.
Ahhh, so many choices, so little time (and money)
Old Jan 10, 2008 | 07:39 AM
  #48
cfdfireman1's Avatar
act
Originally Posted by bboy_RES
the ACT Street Disc Clutch Kit w/ Flywheel (unless you guys can recommend me a good/affordable clutch for a daily driver that can handle a few launches at the strip). 400's?
https://www.evolutionm.net/forums/sh...4&postcount=13
I wouldn't go with the act, Exedy twin or even their single cerametallic would be the way to go.
Old Jan 10, 2008 | 10:36 AM
  #49
9sec9's Avatar
I agree cfdfireman, we also use the Exedy HD Cerametallic Twin.
Old Jan 10, 2008 | 11:07 AM
  #50
bboy_RES's Avatar
sounds good. should i still be looking to upgrade the flywheel or keep the stocker?
Old Jan 10, 2008 | 11:14 AM
  #51
TeStUdO's Avatar
The Exedy Twin HD comes with a flywheel.
Old Jan 10, 2008 | 11:19 AM
  #52
EvoIXMR's Avatar
Anyone get the SS race pipe FP offers with the green install kit? Will it work with an ETS kit?
Old Jan 10, 2008 | 11:26 AM
  #53
Nomad4g63's Avatar
i thought about your route but i decided nope! GT35r!!! FTW!
Old Jan 10, 2008 | 12:41 PM
  #54
bboy_RES's Avatar
yeah, but the single + a flywheel is half the price. i'll definitely get the twin if the funds are available.
Old Jan 10, 2008 | 12:49 PM
  #55
Nomad4g63's Avatar
mucho dinero (alot of money)!
Old Jan 10, 2008 | 01:17 PM
  #56
EVO8URV8's Avatar
Exedy Twin may costs a lot more but it's called SAVING UP. That's what I did and never been happier.
Exedy Twin = FTMFW
Old Jan 10, 2008 | 01:32 PM
  #57
sparky's Avatar
Originally Posted by EvoIXMR
Anyone get the SS Race pipe FP offers with the green install kit? Will it work with an ETS kit?
You are asking about the complimentary, stainless steel hash pipe with the high-temp, ceramic bowl, correct?
Old Jan 10, 2008 | 01:47 PM
  #58
9sec9's Avatar
sparky, now I know where you got that name!
Old Jan 31, 2008 | 05:37 PM
  #59
diiirk@AwdMotorsports's Avatar
Originally Posted by RevMoto
On 4 wheel slides car he hit 11.4@122. This was on 19's with ****ty tires. The thing would not hook up and almost put him into a wall every time. Wish we could have gotten more runs with better wheels on it. This was with a downpipe with dump, fujita uicp and intake, mbc and meth. The car could have easily gotten close to your times. This is also at the worst track in the world. Moroso FTW. He dynoed 438whp. You tell me that the green is worth it after that.
Yes, he indeed made alot of power on a stock ix turbo. But that was with like 34psi and meth. swap that stock turbo with the green and run same boost levels and meth, i think the green will outshine that ix turbo by alot.
You cant compare just swapping to a green against a ix turbo thats running crazy boost and meth. how bout crazy boost and meth on the green, there will be a big difference.
I just placed an order for my green today. My car makes 350 with all the bolt ons. Im staying away from cams and i do not want to do meth, so my options were leave it as is, bc there are no more mods left, or swap to a green and gain a good 30-40 hp on pump. if i can make near 400 on pump just by swapping, then im satisfied. In some cases you can say a green is not worth it, but to say that the green is not worth it in all circumstances is just stupid.
Old Jan 31, 2008 | 06:44 PM
  #60
EvoIXMR's Avatar
No sherlock, this FP race pipe which won't fit on the turbo outlet the way it should....
The pipe needs to point to passenger side to meet up with the LICP and won't as it hits the FP actuator - Anyone else have this issue!
