Transfor case seals
Old Jun 11, 2008 | 05:56 PM
C6C6CH3vo's Avatar
The mitsu dealer parts shop will get the oring #'s for you. They are alot more reasonable people than the service folks.
Old Jun 15, 2008 | 04:09 PM
insanechief's Avatar
Well im deep into it.. and no big problems yet, got my axles out. One of these threads told me to take off the center beam(the one that runs from front to back of car) off, but that has a motor mount on it. That makes no sense to me.
will the transfer case come out without removing that?
Old Jun 15, 2008 | 04:13 PM
acct918's Avatar
i donno if its the same thing but according to the dealer, my right axel transmission fluid is leaking and now my car makes a grinding noise when i start up to accelerate. Taking it in soon and hope warranty covers it
Old Jun 15, 2008 | 04:50 PM
Good luck with that warranty. I got voided with simple bolt ons. And they tried to fix my leak 3 freakin times.
Old Jun 15, 2008 | 05:02 PM
jmelocik's Avatar
Have you moddified your tranny or transfer case at all? Sounds to me like you have a ligitimate gripe to call Mistu corporate about. They have to prove that the mods that you put on caused the failure and since they have already worked on the same problem three times you fall under the lemon law. Check it out.
Josh
Old Jun 15, 2008 | 05:59 PM
i agree with you jmelocik but i have allready fillied a claim against Mitsu and talk to corp office and they said "Your srewed" the hole mag moss act dont do damn it. when it comes to the big office.
I have not even touched my tranny. all i have is simple bolt ons.
Old Jun 16, 2008 | 07:49 AM
_Evo7_'s Avatar
Ouch. Sounds like the splines on the axle have worn out and it's slipping, also causing it to leak...
I had a similar problem with my car, but my axle actually came out on the right side
Old Jun 16, 2008 | 08:16 AM
EVO8emUp's Avatar
Try spraying some lube in the o-rings so everything slides together easier.
Old Jun 16, 2008 | 09:30 AM
Can transmission fluid get into the transfer case through the o-ring seals? Is this possible?
Old Jun 16, 2008 | 09:45 AM
fkw958's Avatar
I'm pretty sure my transmission fluid was leaking into the tcase when i did my clutch 2 weeks ago. When I drained the fluids, the rear diff was clear yellow but both my tranny and tcase fluids were murky brown. there doesn't seem to be an external leak. Do I have to fix this or is this fine?
Old Jun 16, 2008 | 09:52 AM
I had the same thing. Both looked the same but i do have an external leak. This is the reason for the teardown.
Old Jun 20, 2008 | 04:38 PM
I pulled the Tcase back and both of those seals were in good shape from what i seen. But in the process of of draining my fluids i found that my tranny was transfering fluid to my Tcase. There was 1.2 qrts in my Tcase. I have decided to have shep rebuild it.
Old Jun 20, 2008 | 05:57 PM
hey fkw958 did you ever find out what your problem was?
Old Feb 12, 2009 | 10:18 PM
AutOtaku's Avatar
bump i need answers too. i believe mine could be leaking and my evo is plain stock ;((
Old Feb 12, 2009 | 10:44 PM
SpinninAll4s's Avatar
Your having the same problem as I did. I thought it was the seals...they where replaced, turned out to be a crack between where the t-case bolts into the tranny:
I know its hard to see but it was a hairline crack. Sent It out to shep and they took care of me. Make sure you tell them your exact promlem. Hope this helps out!
MurderInc
Evo X How Tos / Installations
20
Dec 16, 2022 12:05 PM
Dallas J
Sep 10, 2019 11:45 AM
evo10fanatic33
Jun 19, 2017 09:37 AM
stunna2o1
Jan 25, 2016 07:02 PM
stunna2o1
12
Jan 19, 2016 11:44 PM
