boost activated cutout FTW
Old Jan 12, 2008 | 05:10 PM
kaonashi's Avatar
LOL well i was searching for some V band flanges and i found this. Look interesting.
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
Old Jan 12, 2008 | 05:12 PM
NoisyTurbo's Avatar
You do know that unit was designed for an inline system and the valve does not seal 100%. So it does leak.
Old Jan 12, 2008 | 05:14 PM
kaonashi's Avatar
tell me why would i want it to seal isnt that the point for it to let more air out?
Old Jan 12, 2008 | 05:18 PM
CAD EVO's Avatar
You want it sealed when the valve is closed which is the point of a valve, This would be a exhaust leak infront of your cat. You buy cutouts so you can have less noise and more low end torque due to more back pressure. The exhaust might also leak into your cabin which isnt the best thing for you. A leaky cut-out doesnt have the same advantages as one that seals. As soon as I installed my 3" catless tbe I noticed a loss in low end torque, very gutless sometimes on a hill start.
Old Jan 12, 2008 | 05:19 PM
90GSX-03EVO's Avatar
Not sealing when not in boost = exhaust leak.
Old Jan 25, 2008 | 02:13 PM
matt55's Avatar
how do you know this ?
Old Jan 25, 2008 | 02:22 PM
4WS Tuning's Avatar
I run a cutout on my car with a stock catback to cut down on noise...
The biggest issue i see with this design is the angle of the exhaust... its 90 deg bend instead of a smooth flow out...
This looks more like a noise maker than a power mod..
This is the unit i run on my car
http://www.jegs.com/webapp/wcs/store...51312_-1_11529
For the electic part i use Race Ready, they have a lifetime warranty that they actually back. After 25k, year and a half later mine started leaking and they had a 1 day turn around time. All cutouts will eventually leak, but not after a month like my qtp one did... Luckily i was able to return that...
http://www.jegs.com/webapp/wcs/store...57985_-1_11529
Cheers!
Old Jan 25, 2008 | 03:50 PM
kaonashi's Avatar
I was just showing everyone what i had found. If i get a cutout its going to be McCord point blank.
Old Jan 25, 2008 | 07:41 PM
Jean's Avatar
I just run a second wastegate on the downpipe. I think it showed a 30+ plus HP gain on the dyno (not 100% on the numbers, testing was done over a year ago on a friends car).
iskat3
Jan 20, 2013 08:46 PM
boonkae
Apr 25, 2009 07:37 PM
igo4bmx
Feb 17, 2009 02:50 PM
Malik_EvoIX
31
Feb 5, 2009 10:19 PM
bo0oost
15
Oct 14, 2004 11:42 PM
