Which oil
Old Jan 14, 2008 | 06:32 PM
  #61
evolved83's Avatar
Originally Posted by sleeper3
A few weeks, but don't quote me on that.
Just make sure the used M1 is pristine, lol, my used oil container has seen lots of different oils (tranny fluid, antifreeze, etc.) in recent months.
I have a brand new container i put it in, so I think i should be fine. I am going to contact blackstone labs tomorrow.
In comparing amsoil to the mobil 1, i don't think it will be a good test because the amsoil is 0w-30 (for winter) and mobil1 is 10w-30.
Old Jan 14, 2008 | 07:53 PM
  #62
VT Mitsu's Avatar
Originally Posted by bluebyu36
oil for the evo is
looking for enlightenment...what is that? from? think it says "partial synthetic"?
sorry for OT
Tom
Old Jan 20, 2008 | 03:09 PM
  #63
revo_phoenix's Avatar
Originally Posted by 90GSX-03EVO
the video was less than a minute long...would you happen to have the rest?
also...hope everyone will still post up their results from the lab as i would like to know if i should still be using mobil...
Old Jan 20, 2008 | 05:36 PM
  #64
90GSX-03EVO's Avatar
I can't find the rest of it. I know I had it before Timzcat's server was taken down. I wonder if he still has it. That server was awesome. It needs to come back in some form. EvoM would be great with an FTP server again.
I think I'm going to go put that in the board suggestions forum.
Old Jan 21, 2008 | 07:24 PM
  #65
thanks! hopefully you guys will post it
i'm curious to see it.
Old Jan 21, 2008 | 07:27 PM
  #66
sorry for OT
Tom
If you've never used it, then you probably don't need it.
Old Jan 22, 2008 | 02:46 PM
  #67
Oil Doc's Avatar
Here is a Comparison of 10W-30 oils including Mobil 1
http://www.amsoil.com/lit/g1971.pdf
Doc
Old Jan 22, 2008 | 02:48 PM
  #68
lemmonhead's Avatar
you cant go by that test. YOu need the test by a 3rd party.
Old Jan 22, 2008 | 03:27 PM
  #69
Oil Doc's Avatar
AMSOIL publishes test Data performed by several of the Top Testing Facilities in the US.
You don't think RP, or anyone else for that matter, is going to publish results where they didn't finish on top, do you ?
Doc
Old Jan 22, 2008 | 04:00 PM
  #70
well...they did place a -close second- in the "helps engines start easier" test
Old Jan 31, 2008 | 04:34 PM
  #71
VT Mitsu's Avatar
hardy har har :]
fess up...
Old Feb 4, 2008 | 03:13 PM
  #72
Oil Doc's Avatar
Yep, And you can add Stoddard Solvent to any oil to make it start easier by lowering the VI of the oil and lower lower oil temps as well.
There are additives out there that use SS for that reason... They just don't tell you that it takes away the lubricity of the oil... But hey, it starts easier.. LOL
I just did a Car Show this past weekend... UNBELIEVABLE how many people are still nuts enough to use oil additives because they either saw on TV, or one of those BS Demo's with the guy using a "One Armed Bandit" to test oils and additives.....
Doc
Old Feb 4, 2008 | 03:58 PM
  #73
hennessey01's Avatar
this is sad......i just had a dealership tell me to always use mobil 1.....they said "it cant go wrong.....every car that come on hasent had a failure using mobil 1"
Old Feb 4, 2008 | 09:39 PM
  #74
evilempire76's Avatar
Here are some interesting links in regards to the subject at hand:
http://www.bobistheoilguy.com/
http://www.dysonanalysis.com/
http://www.oaitesting.com/sampling.htm
Old Feb 11, 2008 | 07:13 PM
  #75
Oil Doc's Avatar
Mobil 1 EP is a PAO Synthetic... BUT, by law to be called 100% Synthetic, it only needs to be 30% PAO..... Mobil 1 is still a good oil... Mobil uses a carrier oil to keep additives blended as the cost to keep additives blended in a PAO Stock is expensive, hence, partially the cost difference of AMSOIL... Motul 300 is a great oil, Ester based which has it's own share of problems such as moisture and seal compatibility and that is why The Best Synthetics are PAO w/Esters....
Put Royal Purple on on the rollers of your garage door... that is about what it is good for.
Eneos oil.... maybe just above Royal Purple... Maybe
Filters.... I recommend the WIX over the AMSOIL as the AMSOIL May go into By-Pass with hard driving and the WIX is a Synthetic Glass filter.
Oil Analysis..... It does absolutely NO GOOD to do an analysis and change brands and do an analysis on that oil and so on.... That is why I dismiss most of the analysis on the websites mentioned..... You go by ASTM Tests...
Doc
