boost problems
Old Jan 14, 2008 | 04:57 PM
Mr. Evo IX's Avatar
If your using the stock boost solenoid then you need the stock boost lines since they contain special air limiting orfices. If you have a mbc you can get rid of the stock lines and just use regular vacuum lines.
If your seeing 10-12 psi then you are probably running wastegate spring pressure. In order to boost more than the wastegate you will need to bleed some pressure off using either the stock boost system or a mbc/ebc.
Old Jan 14, 2008 | 04:59 PM
fame118's Avatar
bump
Old Jan 14, 2008 | 05:02 PM
fame118's Avatar
any suggestions to try please help
Old Jan 14, 2008 | 05:04 PM
fame118's Avatar
will try thanks mr evoix
Old Jan 14, 2008 | 05:06 PM
krazirob's Avatar
like said above. when using the stock boost controller, the stock lines must be used because they have restricter pills in them.......when using a aftermarket boost controller you need to use just regular vacuum lines.
now when i did my boost controller i had to use the stiffer spring that came with the boost controller and put that one in since the spring that was already in it was too soft. I.E not hold enough boost....
also make sure you grease up the bearing inside the boost controller when you switch springs.
when you indeed do use the aftermarker boost controller either sip tie the stock lines that connect to the stock boost controller closed or cap them off with a rubber cap (can get at any hardware store for 50 cents and looks neater).
there is a couple installation guides you can find in the installation forums to help you make sure everything was put in right.
that could not even be the reason but just check everything out at least, wont hurt ya know
fame118's Avatar
im trying to get back to the stock boost settings which is 17 to 18 psi
Old Jan 14, 2008 | 05:08 PM
fame118's Avatar
thanks krazirob im willing to try anything to get my car stock i love evos and i bought this one and its giving so many problems.
Old Jan 14, 2008 | 05:09 PM
fame118's Avatar
the boost controller i bought was a turbo smart manual single stage. The only adjustments it has is to turn boost up or down
Old Jan 14, 2008 | 05:10 PM
krazirob's Avatar
no prob man, thats why i always do my own mechanic work so i know what to look for when something messes up.
if you dont know then learning will be easy.
Old Jan 15, 2008 | 03:37 AM
fame118's Avatar
bump
evolution520
Oct 11, 2013 11:25 AM
josh3305
Mar 31, 2012 11:44 AM
evo1981
Jul 14, 2010 05:23 AM
mattz09
Apr 11, 2010 08:55 AM
