boost problems
Old Jan 14, 2008 | 04:27 PM
fame118's Avatar
boost problems
hi i have an 05 mr and been have some boost problems. I bought the car and i was only getting 5 to 6 pounds of boost. It had a forge wastegate so i replaced it with an oem and got up to 10 to 11 pounds. I have changed all the hoses to silicone and still didnt get back the stock 17 pounds. It also have a bigger intercooler i am thinking maybe thats a reason why. Does anyone have any ideas please help. Any suggestions would help out alot thanks.
fame118's Avatar
bump
Old Jan 14, 2008 | 04:30 PM
DSM GSR04's Avatar
tighten all hose clamps. thats your problem.
Old Jan 14, 2008 | 04:31 PM
silver9mr's Avatar
going from the stock ic to a bigger one should only decrease the boost by 1 psi u should probly check all the ic pipeing for boost leaks
Old Jan 14, 2008 | 04:39 PM
krazirob's Avatar
i got more boost with my full ETS setup.....had to lower the boost until i could log it and street tune.......
Old Jan 14, 2008 | 04:41 PM
fame118's Avatar
did check all the pipes more than a few times and tighten them up and same results.
Old Jan 14, 2008 | 04:42 PM
fame118's Avatar
i checked for boost leaks a few times and still cant find anything. I have no idea wat to check for next
Old Jan 14, 2008 | 04:45 PM
Mr. Evo IX's Avatar
is the turbo directly connected to the wastegate?
Old Jan 14, 2008 | 04:47 PM
IEXCELR8's Avatar
Do you have the stock bov with stock lines?
Old Jan 14, 2008 | 04:49 PM
fame118's Avatar
i dont really know my mechanic disconnected the wastegaste to test it and we were getting full boost. Then we connected it back. I bought a boost controll and still it didnt go up from 10 to 11
Old Jan 14, 2008 | 04:51 PM
fame118's Avatar
i changed to the stock bov to the go fast bits stealth. I put the stock one back to see if it was the bov but no improvement
IEXCELR8's Avatar
Did you put the stock lines back in?
Old Jan 14, 2008 | 04:53 PM
fame118's Avatar
i didnt have to change the lines the go fast bits bov is a direct bolt on
krazirob's Avatar
when you put the MBC in did you cap off the stock boost solenoid??? you need to when you connect the wastegate and j tube to the MBC............
Old Jan 14, 2008 | 04:56 PM
fame118's Avatar
krazirob im not that advanced my mechanic is but he is running out of ideas of wat it can be. If u can put in in more simple terms i can explain to my mechanic the ideas. Thanks
