greddy type s bov
Old Jan 17, 2008 | 02:08 AM
Turbodemon's Avatar
greddy type s bov
just had a quick question regarding a bov on the evo i bought.
it has the greddy i beleive to be the type s one (one that recircs and has a purp top)
upon closer inspection i noticed a little metal tube with a hole (wich looks like a vacuum hose should be attached to it)
is this fine with the evo?
i come from a mr2 turbo with a hks bov and i had vacuum lines attched to it but how does it fair on the evo not having anything attached to it.
if it does need something there where should i connect this outlet to?
Old Jan 17, 2008 | 02:54 AM
DR EVO_38's Avatar
If im not mistaking you can run a vacum line from that nipple to the other nipple on the BOV. so the one on top to the one on bottom.
Old Jan 17, 2008 | 04:13 AM
tkklemann's Avatar
On the Greddy Type S, to nipple that comes out of the purple top is the one to connect to your manifold vacuum/boost source, the one below the cap that is attached to the body of the BOV should be left open, ie. nothing attached to it.
Old Jan 21, 2008 | 01:12 AM
Turbodemon's Avatar
if i am having very minor issues with the engine rpms diving a little to low wich way should i turn the nut on the bov?
Old Jan 21, 2008 | 01:13 AM
Turbodemon's Avatar
ty btw for the info i really appreciate it
Old Jan 26, 2008 | 06:14 PM
compscibOi's Avatar
If you are referring to the nut on the top of the BOV, that is for a harder or softer VTA pressure. There should be arrows indicating the desired method.
As far as low RPM's with a VTA bov, I have read and experienced in person TONS of cars with VTA BOV's and most people recommend a tune to fix that.
More experienced can chime in.
Old Jan 26, 2008 | 06:34 PM
vexgaffer's Avatar
lancershop guide
Here is a install guide for lancershop.
http://www.evomoto.com/tech_info.php...3_10&tech_id=6
I would check it out and double check what you got to make sure everything is in place, and I think it tells you what to do for the low rpms. not sure tho. I think you may be set to hard.
whotippedmycow
Jul 30, 2013 09:00 PM
escape1221
Nov 18, 2012 12:06 AM
03evo8kevin
20
Aug 2, 2009 09:39 AM
bluebanana23
Oct 25, 2006 09:53 AM
2004BlkEvo8
Nov 10, 2004 09:08 PM
