output shaft
Old Jan 18, 2008 | 09:12 AM
fknlowpsi's Avatar
output shaft
is there another way to remove the output shaft to removed the TC/ instead of using a slide hammer is there a puller? i know it is a dumb question and it has been asked 1 million times.
Old Jan 18, 2008 | 10:18 AM
fknlowpsi's Avatar
guess not...... bump
Old Jan 18, 2008 | 10:24 AM
itzwolf's Avatar
That is the only way I have removed them as its in there snug and there is a spring clip, and takes a fair amount to release it.
Old Jan 18, 2008 | 10:54 AM
justboosted02's Avatar
No. must use slide hammer
you can borrow the tool for free at autozone
Old Jan 18, 2008 | 11:07 AM
fknlowpsi's Avatar
i will have to hit them up thanks boosted
Old Jan 18, 2008 | 11:37 AM
ny-quiL's Avatar
I did the borrow - and what they do is charge your credit card the amount it costs (140$) then refund the amount after you return it.
Old Jan 18, 2008 | 12:04 PM
fknlowpsi's Avatar
did it come with the right bolt no for the shaft?????
Old Jan 18, 2008 | 12:07 PM
Nez136's Avatar
I would just buy a slide hammer, its nice to have for future clutch jobs
Old Jan 18, 2008 | 12:16 PM
bevolucion's Avatar
yes there is
i bought a 2 1/2 in 8m bolt put a couple of big washer(wide) and a nut to keep the washers tight to the head of the bolt i also put a big nut(cv axle) other than the 8m one, so the washers wouldnt bent, i used a straight pry bar about 18" long so it woulnd't hit the floor if your doing it on the floor, screw about 3/4 of the bolt in and then pry it using if i remember the control arm as lever. 2 or 3 times and it was out , i was surprised how well it worked.
Old Jan 18, 2008 | 12:18 PM
bevolucion's Avatar
i just did it last weekend before i crashed my car today. (cost of the gig) 5 bucks bolt , washer and 8m nut
Old Jan 18, 2008 | 02:39 PM
UDLOZ2's Avatar
slide hammer time
Yota Eater
Jul 20, 2016 10:24 PM
Dvolution
Feb 25, 2013 03:07 PM
snafufx
11
Mar 26, 2011 09:00 PM
wazmunstr
23
Jan 30, 2011 06:23 PM
Nastynine
Apr 10, 2010 05:45 AM
