400whp with 98 octane.
Hi all.
I'm looking for advice and guidence from you all to help me with my turbo and injector selections.
Here is the deal.
I wish to make about 400-430whp.
I only want to use pump gas (the best pump fuel in Australia is 98 octane).
What turbo would best make this power without too much lag? (I dont mind a some lag just not excessive amounts)
Also I don't want to use alcohol/meth/water injection.
Lastly, with the turbo you recommend, what size injectors should I match with it?
Thanks for your comments in advance.
Here is the deal.
Look for some posts by 9sec9 or OKIX. I would go along that route. Below is a similar list of what they did.
In addition to your typical bolt-ons (exhaust, 255 fuel pump, boost control)
20G-LT/FPGreen w/ 680cc injectors. The Meth Kit will help with the fueling. Also get some Cams, port your intake and exhaust mani, and get yourself a 65mm TB. With a good tune, I think you can reach your goal.
Anyone want to add or take away from that list?
I you want that power level from a bolt-on turbo w/o using drugs(Alky), then your only option presently available is the Forced Performance EvoGreen turbo. For 430 WHP you are going to need full boltons. Another option is a turbo kit with a 50-Trim or a 3076 turbo.
98 octane R.O.N.(Research Octane Number) is equivalent to our 93 octane R+M/2 pump gas.
Further to my previous post. This will be with the stock block.
I am thinking along the lines of a 3076. (If used with only pump gas can you recommend injector size? 880cc?)
I've been researching this for awhile now, and have seen some people get some great results with a 35R (or the similar PT61) with a stock block.
I have a feeling that this might be too laggy though. I have read that some people claim that the pt61 (especially with the s-cover) doesnt lag too much.
Any help?
Any help?
samredka
Jan 19, 2016 07:37 PM
riceball777
25
Feb 15, 2011 08:51 PM
jag0
55
Aug 30, 2010 01:23 PM
