TRE 3.73 or Simalar Help.
TRE 3.73 or Something like it Help.
I recently purchased a trans from a local person under the impression it was a Stage II TRE Rebuild with HKS 4.11 Final Drive.
What I found out is that it is the TRE 3.73 final drive not the HKS 4.11.
I got a great price on the deal and I had AndrewTech tear it apart to inspect, everything turned out great with it during inspection, they told me it was not stock final drive, but I didn't ask them to determine the final drive ratio, until now I didn't expect it to be different then advertised.
So I'm looking for some info from folks that are using or have used this in their Evo.
Thanks.
Thanks.
I haven't used these but...
The TRE site has specs on how it affects your MPH with that gearing. Basically you will have super long gears with 3.73's.
SPEED @ RPM = 7500
4.53 oem final drive
4.11 HKS final drive
3.73 TRE final drive
1st = 40 - 47 - 50mph
2nd = 64 -70 - 77mph
3rd= 89 - 97 - 106mph
4th = 122 - 132 - 145mph
5th = 174 - 190 - 210mph
And if you already knew this, then oh well free bump lol
SPEED @ RPM = 7500
Yup already know that - Sadly I'm not good with numbers. I am looking for more like - what their impressions we're how much power it took to get the same ET as 4.11s etc.
on the road...given the same modifications, driver and power on two different carsone with stock gear ratio and another the a longer gear ratio: say 3.73...which would be faster from 0- top speed?
thanks
thanks
I'm anxious to hear how gear changes have affected stock turbo or upgrades turbo's. I think even on stock turbo, it would be kicka$$. Power band would be quite fat, maybe a little laggy at first, but I think there would be much to gain. Better 0-60? I would hope so, and expect so.
FS[Northeast]: WTB evo 9 final drive
gigitalon
Jan 26, 2017 03:23 AM
FS[West]: TRE prepped HKS 4.11 Final Drive
letsgetthisdone
39
Oct 19, 2015 10:41 AM
FS[Mid-Atlantic]: TRE stage 3 trans with HKS 4:11 final drive
Turbo01s2k
Feb 10, 2015 01:05 PM
David Buschur
Nov 17, 2009 02:40 PM
