Evo 9 Spark Plug List, Also how to read plugs.
Old Jun 29, 2009 | 03:47 PM
  #121
bboypuertoroc's Avatar
Veteran: Army
Originally Posted by project_skyline
Can I use denso IW20's in my 8? They would be 2 step colder if i understant correctly right?
This thread is about Evo IXs, not Evo VIIIs. Please pay attention to the thread title.
Old Jun 29, 2009 | 03:51 PM
  #122
Veteran: Army
Originally Posted by DG Motors
For an evo 9:
We use NGK LFR6A-11. Gap to .022.
They are copper plugs.
Affordable and work great at $25 a set.
I'm guessing this would be for a stock IX.
How about a modded IX, running a Red and 30psi on pump gas?
I'm running the Denso 1 step colder iridiums right now, and I'm getting some nasty misfires (been running them since Dec, gapped at .022, started having issues recently and plan on buying new plugs today or tomorrow). A cheap plug that works to hold me over would be fantastic (even better if they actually work good in my setup).
Old Jun 29, 2009 | 10:30 PM
  #123
project_skyline's Avatar
and its full of info about 8 plugs too. I can read!!! I wanted an answer not a smart *** remark.
Old Jun 30, 2009 | 07:54 AM
  #124
DawnoffateX's Avatar
Full bolt on IX with stock turbo (including o2 housing manifold etc)
I'd prefer to run copper plugs and change them out every two oil changes (6-7k miles)
What should I be looking at?
Old Aug 1, 2009 | 09:52 AM
  #125
PlanoEvo's Avatar
For an evo 9:
Can you elaborate why using a plug with a 6 heat range works good when the stock is 7?
Old Aug 3, 2009 | 03:02 PM
  #126
PlanoEvo's Avatar
anyone?
Old Aug 9, 2009 | 08:36 PM
  #127
PlanoEvo's Avatar
For an evo 9:
I have these in my car today and all seems okay.Going to examine one after some spirited drives in a couple days. If you(DG) use these in the IX what power levels are you using them to.
Old Aug 10, 2009 | 12:18 AM
  #128
slowr_evo's Avatar
this is a good thread, bc so many ppl get the wrong impression, thinking Evo 8' plugs will fit Evo 9's and they wont, bc of course the length issue. thanks DONE for this very important info.!
Old Aug 10, 2009 | 06:00 AM
  #129
DG Motors's Avatar
We have used these plugs up to 42psi with a dli2 gapped to .022 no misfires on a 650whp evo 9.
Old Aug 10, 2009 | 06:16 AM
  #130
PlanoEvo's Avatar
Wow thats impressive and if that indeed is the case it seems to indicate that colder plugs are maybe not needed. I just worry since plug makers will tell you that running a hotter plug could cause engine damage. Anyway they seem to run very well in my IX and thanks for the info because I would rather run copper than iridium anyday.
Old Aug 10, 2009 | 06:25 AM
  #131
cij911's Avatar
That is silly....The stock plugs should last you well past 40K miles....
Old Aug 10, 2009 | 06:31 AM
  #132
SPANKED's Avatar
Almost time to replace mine... thanks for the info!
Old Aug 10, 2009 | 07:03 PM
  #133
PlanoEvo's Avatar
okay then why do most of the dsm and evo 1-8 users prefer not to iridium? I tell you why iridium sucks as a conductor meaning you lose ignition power and require smaller gaps. Copper is a much better conductor and cheaper hence your wiring in your house. Only silver beats copper and not by much but costs much more.
Old Sep 10, 2009 | 04:38 PM
  #134
sleeper04's Avatar
would one step colder plugs benefit me? mods in sig also on 91 pump gas. also what gap ? or just go to the dealer and get them ?
Old Sep 11, 2009 | 02:28 AM
  #135
tweaker41's Avatar
What's you hp/tq? If your not having ignition problems leave it. They say after about 100hp over stock go one step colder. Gap depends on your car. What works on some doesn't work on others. On pump gas I did .024, meth .022, SparkTech .028, all one step colder plugs.
