grind into 5th gear when fully stpping on clutch
Old Feb 5, 2008 | 09:42 AM
J_s0 Fresh's Avatar
so i just bought an evo IX works fine...driving on the freeway i was getting into fifth then i heard a grind noise but what questioned me was that i was pushing on the clutch all the way down...might i add this only happens at high RPMs when im off boost no grind sound..what could this be? and when i first start the car in the morning, and get into reverse a loud Clunk noise sounds too...i have no idea whats going on..i did try to search but maybe i was typing in the wrong things to search for..i Need help before this gets any worse...Thanks guys..
Old Feb 5, 2008 | 09:47 AM
MasterNater's Avatar
I'm not sure what's going on with reverse, but it definitely sounds like you have a classic case of 5th gear grind. My car does the same thing. 5th gear only grinds when I shift out of 4th @ redline. The problem is a bad syncro and it is very common...unfortunately. If you just bought the car, and you still have a warranty, you can TRY to get it fixed but generally they will only cover it if the problem happens under "normal driving conditions". Of course, coming out of 4th gear at 7k rpms isn't considered normal driving.
Old Feb 5, 2008 | 09:56 AM
jezefink's Avatar
what clutch is in the car?...if its act..they are pretty notorious for the 5th gear grind..
Old Feb 5, 2008 | 10:02 AM
spooch's Avatar
i have the same thing, and when i put it in reverse 8 out of 10 times theres a real loud clunkkk unless i hold the clutch put it in first then go to reverse its reallly strange.. my 3rd gear also is really notchy and grinds under non-normal driving conditions... tookit to dealer and drove with the tech. he drove and shifted very slow and says that theres nothing wrong with it.. hetried being a hotshot doin 90 on a 55 and putting in the clutch then waitin 2 seconds to 5th and says its as smooth as butter... *******s
Old Feb 5, 2008 | 10:52 AM
J_s0 Fresh's Avatar
masternater i totally agree with you with the normal driving, but man its just annoying.
Jezefink, i dont know what clutch i have im assuming its stock but who knows the car i bought had mods on it already from the dealership so..i have no idea..ill check on it..
do you guys know how much it would cost if i didnt go through the dealership? approx. what am i lookin at here for price?..
Spooch, yea i have to do the same dang thing its either 1st or 3rd first then it doesnt do it..i dont know, bad synchro for reverse also?...
Old Feb 5, 2008 | 01:33 PM
Well, I think it would be a waste of time having just the syncro replaced, especially if it's not under warranty. I think there have been people that have had there bad syncros replaced under warranty by the dealer, only to have the issue come back months down the road. I would say that if you plan to keep the car for a while and don't want transmission problems again, send the trans out to Shep or Buschur for a complete rebuild. Chances are it's going to cost you around $1,000 depending on what you want done.
Shep
http://www.sheptrans.com/catalog.php...&cat=EVO&id=11
Buschur
https://secure.buschurracing.com/cat...a2b34518d5cbc5
Again, it depends on how long you're keeping the car, what you want to do with the car in the future, and how much money you have to spend. But IMO, having it rebuilt by one of the shops listed above is money well spent.
Old Feb 5, 2008 | 04:10 PM
jezefink's Avatar
hey its very simple to see what clutch you have..jack it up and get underneath it..then theres a dust cover that goes over the trans..right by the starter take that off..and look in there with a flashlight you can see what clutch is in it..usually..
also check out
www.dogboxracing.com...if you are around the east coast..alex is great at evo trannys...
Old Feb 6, 2008 | 04:26 PM
J_s0 Fresh's Avatar
do you guys know any good places on the west cost cuz thats where i reside?..and why does the synchro on our cars become crap after awhile even when its replaced??
Old Feb 6, 2008 | 06:17 PM
t51splbb's Avatar
Most of the people on the west coast send their transmissions for rebuilds to either TRE or Shep.
blueprint
Mar 27, 2017 11:29 PM
YIfuEVO
Jan 26, 2017 06:44 AM
Royal Evo
Mar 14, 2016 03:51 PM
futurevowner
Lancer Tranny/Drivetrain Tech
36
Apr 28, 2008 09:54 PM
Kurt
Lancer Engine Tech
20
May 22, 2006 05:10 AM
