Can Gt3076r hit 460 whp 93 pump??
Old Feb 8, 2008 | 08:15 AM
  #46
Ludikraut's Avatar
I think 450whp on an IX running a gt30r is possible, but it will probably take a bunch of supporting mods to get there, and if you're planning on road-racing the car, you may want to back off the tune slightly. As a point of reference, on my VIII, I run a 50 trim with pretty much everything you can think of and I'm between 400 and 410 whp @ 21psi. Your IX should be able to boost slightly higher and MIVEC will help too. Please post your results after the FR TS kit has been installed and tuned. Should be a beast.
l8r)
Old Feb 8, 2008 | 08:20 AM
  #47
HaVoC RR's Avatar
will do post results .i cant wait
Old Feb 8, 2008 | 09:29 AM
  #48
gamebred26's Avatar
dude just put some 100oct in there and crank it to 29 lbs.
you will def be up there..
Old Feb 8, 2008 | 09:53 AM
  #49
deadbeatrec's Avatar
dude, the fact is that anything over 400whp with a 30r using 93 octane only is really hard to do. most 35r's only hit 440whp with 93.
Old Feb 8, 2008 | 02:02 PM
  #50
mpevo8's Avatar
buschur hit 535whp on 93 on a 35r. keep in mind this was on his mustang dyno. really low reading. no meth or alchy. just send the car to him and let him do magic. the same car trapped 135 on 93 octane only.
Old Feb 8, 2008 | 02:59 PM
  #51
psphinx81's Avatar
on a stock block/head, no. not without meth
with a built motor/head, yes.
Old Feb 8, 2008 | 07:24 PM
  #52
turbodreamz21's Avatar
i will do 3076r with aqua mist kit and i will get it tuned buy BIg al at ICS / dynoflash i iwll do 93/meth
Old Feb 9, 2008 | 09:45 PM
  #53
DynoFlash's Avatar
This is member deadbeatrec's new dyno sheet on 93 octane and alchy - at 28 psi of boost
ATP 3076 turbo - Stage IV with drop in pistons and rods - 03 evo 8
Old Feb 9, 2008 | 10:20 PM
  #54
hey whats up dyno flash i hope this is big al ??? ( let me know) i have seen all your videos u r a amazing tuner i plan on getting my parts end of february and isntalled by beggening of march
i have a few questions about your awau msit kit that u sell
i wanan run 93 and meth on stock block i have cams int he head but thats about it for head parts
do u think i would see 480 whp witht her 3076 and meth? also im not trying to be a dyno queen but obviosuly ppl love to see there car hit those numbers
im also wondering how much u sell the aqua msit kits for and how much it would be for tuning for my 03 evo 8
liek i said once i get everythign in becuase im buyign turbo off a freind and i know a few kids in Salem MA who own a speed shop who will install aprts for me but then ill be driving down to STamford for your awesoem tuning
just want to know a few things thats all
another ? is could i make the 3 hr drive on a untuned evo with the 3076r without hitting boost or would it not be smart at all to do it??
thnaks
Old Feb 10, 2008 | 03:48 AM
  #55
sparky's Avatar
465 WHP from an VIII, on 93 octane, with a 3076/.63 housing, unported head, unported intake manifold, stock TB, stock ECU, and mild cams, seems a bit wishful. For starters, your modest upgrade list leaves a lot of potential power on the table.
Restricted to just 93 octane fuel, your everyday tune would need to be fairly conservative. The 3076 configured with the small A/R housing is not the ideal pumpgas turbo anyway. If you were to research just how much boost guys with this turbo/housing configuration are able to run on 93, I am willing to bet that as a rule of thumb they can't turn it up much past 23#, w/o really rolling back ignition timing.
I'd venture to guess that limited to 24 PSI,or less, with moderate timing you'll have a hard time surpassing the 410-420 WHP mark. Maybe your best bet is to take it to someone like Sean Ivey. It all depends on the tune. But still, 465 on 93 seems a bit optimistic.
Don't get me wrong. I like the 3076 as a midsize turbo upgrade. However, I'd only run it if I could feed the beast a constant diet of 110 octane fuel. If I wanted 465 WHP on 93, I would start my turbo search, a little bit north of the 30R series. As a minimum, I would look at the 3065, and maybe even the HTA 35.
Old Feb 10, 2008 | 04:58 AM
  #56
sparky's Avatar
Originally Posted by NyC DrifteR
what if it was a twin scroll 30 r .78 and a evo ix u think u can see those numbers?
Being that it's a IX, the Mivec head will give you better numbers than an VIII right off the bat. Aside from this, I fail to see how T.S. vs. single scroll housing will give higher peak power though, given the same A/R.
Old Feb 10, 2008 | 07:46 AM
  #57
j3ffw19's Avatar
my ix with a 3065 and gsc s1 cams made 450awhp at 22psi on pump gas 93. stock bottom end ans stock top end.
Old Feb 10, 2008 | 09:38 AM
  #58
well it mgiht be just me buit isnt the 3076 a bigger turbo than the 3065 or am i JUST dumb lol also the reaosn i went with .63 is cuz of the low spool it can priduce i woudlnt mid goign 3065 if i know it can produce what iw ant but is the 3065 bigger than 3076> alot of ppl told me 3076 is a great turbo for the 2.0 motor but yet you guys can help me out
Old Feb 10, 2008 | 10:50 AM
  #59
wizzo 8's Avatar
3065 is bigger than the 3076
Old Feb 10, 2008 | 10:53 AM
  #60
o well thank you i did not know that i thought the 76 was bigger o so then i might go wtih the 65 nice i can see power levels out of that hoppefully
