Can Gt3076r hit 460 whp 93 pump??
Old Feb 10, 2008 | 11:52 AM
  #61
sparky's Avatar
I think that the 3065 and the 3076 share the same or have equivalent turbine wheels. The compressor side is where they diverge. The 3065 has the same compressor wheel and compressor housing as a 35R.
So the 3065 combines the 35R's compressor side with a 30R(3076, etc.) turbine wheel. It is essentially a faster spooling 35R and should move the same volume of air as a 35R up until about 30 PSI.
Above 30 PSI a true, full-house 35R flows more air than the hybrid 3065 due to the lower backpressure hotside. At any rate the 3065 flows way more air than the 3076.
Old Feb 10, 2008 | 11:55 AM
  #62
turbodreamz21's Avatar
nice iw as looking into Buschurs 3065 kit but i only have 4500 to work with and there kit pluce all the extra needed parts like FMIC clutch...ect exceeds my limit by alot...im wondering if nayone knows where i could buy the 3065 out of the kit just the turbo alone?
Old Feb 10, 2008 | 12:01 PM
  #63
sparky's Avatar
Buschur has two 3065 kits. One features a tubular header and is more expensive. However, if you search on their site or call Dave or Jarrod they can quote you a price on their more economical 3065 kit which features a cast manifold. I'll bet that their 3065 kit which features the cast manifold should fall easily within your stated budget.
EDIT: In fact you should definitely call BR and they'll probably give you a package deal which'll save you some cash on the turbo kit, IC and clutch.
Old Feb 10, 2008 | 12:09 PM
  #64
sparky's Avatar
The turbocharger is put together by Forced Performance in Texas. Buschur Racing and Forced Performance work together on a lot of the Evo upgrade turbos.
Old Feb 10, 2008 | 12:10 PM
  #65
i hope i will prob call david on wed i need BR fuel Rail BR injectors BR race FMIC with piping i need a lsot fo thigns for them i think im goign with act cltuch 6 puck but i saw that manifold i would love to have the tubular alot of ppl see alot of gians with that manifold...maybe i can see what he can do with all of those and tubular manifold maybe a good deal aroudn what i need
Old Feb 10, 2008 | 12:15 PM
  #66
sparky's Avatar
You won't need to upgrade the Mitsu fuel rail for the power level that you're chasing. The BR Race IC is a great piece. You'll need the 850, or 880cc injectors as well. They can advise on the clutch too.
Old Feb 10, 2008 | 12:30 PM
  #67
u really dont think i will need a upgraded fuel rail to flow the more fule to hi wat i want? im looking to go with meth also so i cna hit that 480 whp
so the 3065 with meth u think the stock mitsu fuel rail will be just fine?
Old Feb 10, 2008 | 12:51 PM
  #68
gamebred26's Avatar
remember with meth you use less gas...and less injector..
Old Feb 10, 2008 | 12:59 PM
  #69
really mayeb i wont need 880cc then go for something lower very ncie
Old Feb 10, 2008 | 10:37 PM
  #70
j3ffw19's Avatar
om running 1000cc injectors and im getting ready to install alky and my exedy twin. i will let you know what the outcome is
Old Feb 11, 2008 | 04:27 AM
  #71
deadbeatrec's Avatar
Originally Posted by DynoFlash
This is member deadbeatrec's new dyno sheet on 93 octane and alchy - at 28 psi of boost
ATP 3076 turbo - Stage IV with drop in pistons and rods - 03 evo 8
nice AL
i missed this post.
Old Feb 11, 2008 | 06:56 PM
  #72
wizzo 8's Avatar
1000cc why so big
Old Feb 11, 2008 | 06:57 PM
  #73
scorke's Avatar
NO.
Scorke
Old Feb 11, 2008 | 06:58 PM
  #74
scorke's Avatar
well it mgiht be just me buit isnt the 3076 a bigger turbo than the 3065 or am i JUST dumb lol also the reaosn i went with .63 is cuz of the low spool it can priduce i woudlnt mid goign 3065 if i know it can produce what iw ant but is the 3065 bigger than 3076> alot of ppl told me 3076 is a great turbo for the 2.0 motor but yet you guys can help me out
Your just dumb.
The .63 is a horrible hotside for the 30R, it shouldnt even be considered, if it is then you might as well go with a smaller center section.
Scorke
Old Apr 13, 2008 | 08:56 AM
  #75
j3ffw19's Avatar
Originally Posted by wizzo 8
1000cc why so big
the shop that was tunning my car advised me to go bigger then 680cc and all they had was 1000cc. i cant complain cause they drive great, with alittle bit of starting problems but i think that because of the mini battery. overall iam happy with them.
here is my dynosheet from ams in md
http://forums.dcevoclub.com/showthread.php?t=8631
