MBCs: What you don't like
Old Feb 14, 2008 | 04:01 AM
  #46
tkklemann's Avatar
Originally Posted by CharlieGsanD
one of my personal pet peeves W manual boost controllers is that they tend to vary boost pressure as the temperature changes, most likely due to the spring weakening as the temp goes up & stiffening as the temp goes down....
EDIT: I am using a Hallman MBC in my personal car. Interestingly enough, I built a "Home Depot" special boost controller paying very particular attention to the build. (Read: Very **** building it). I did compare data logs to my Hallman (One car to another car compare JDM MAP logs) and the Home Depot special controlled boost to within 0.4 psi on the other car. I was duly impressed with my built Home Depot special, and so was the guy who's car I put it on. (We reviewed ton's of his data logs to verify it was working correctly.
Thats a good point, but here is something that has helped me out a little (I think, probably the problem too. Ha!).
I moved my boost controller to a custom made bracket that locates it almost over the coolant outlet on the head, parallel to the valve cover, about 3/4" away. I used to have it mounted down just benieth the air filter (Where most aftermarket air intakes put it) and I noticed that it holds more consistent boost up top than below the air filter. Theoretically speaking, it probably would because it doesn't go through the drastic temperature changes up there because the radiant heat keepin the boost controller hot all the time. Reasonably speaking, my AIT's would change quite a bit from my driving conditions, and where I was at the time. Using my AIT as aa "guide" as to what temps the boost controller would see because the MAF was only about 6" away from the controller, it would range sometimes up to +30*F. Mounted in my new location should keep the temperature more steady with the boost controller.
But, the real questions is how much "more steady" it holds is. My guess it hold is about 0.0002344352224% better. He he... Maybe I can do a few 3rd gear pulls and see if it changed in my logs from previous tuning pulls.
Old Feb 14, 2008 | 04:37 AM
  #47
Markley02's Avatar
I bought my Dejon 2 weeks after I bought my evo. When I first installed it I would get a little boost spike. After a few days it went away. Been great since.
Old Feb 14, 2008 | 05:28 AM
  #48
SPANKED's Avatar
Good info...
Doesn't spiking also depend on how you install it?
Old Feb 14, 2008 | 05:47 AM
  #49
tkklemann's Avatar
Originally Posted by SPANKED
Good info...
Yes it does.
Old Feb 14, 2008 | 09:26 AM
  #50
SPANKED's Avatar
So which way has been confirmed to reduce the spike?
tkklemann could you link me to a how to...thanks!
Old Feb 14, 2008 | 09:42 AM
  #51
drb's Avatar
drb
I have the Hallman Pro RX. Works great with very little spike, and it is easy to adjust. I see approx. a 1 psi difference between cold (15F) and hot (100F) outdoor temperatures, which is great as far as I am concerned.
Dan (drb)
Old Feb 14, 2008 | 11:54 AM
  #52
tkklemann's Avatar
This is the exact one that I built, but mine was really thought out. I didn't use a straight up bolt for adjustment, but a stainless socket head with a knob tig welded to it. I drilled my pressure relief hole in a slightly different spot, as well as a few other things.
I also built one exactly liek the one in the picture, and used it in place of my hallman just to see how good it really was. I must say I was very impressed with it. It held boost just as good as the Hallman.
The looks of it leave a little bit to be desired, so I polished the pee out of it. Now it looks like a polished turd. Haha!
EDIT: here is the link: http://www.geocities.com/chmwatson/FAQs/mbc.html
Old Feb 14, 2008 | 12:27 PM
  #53
SPANKED's Avatar
Thanks but I was actually asking about how you installed it, not how you built it.
Wooops you also have that in the link...thanks!
Old Feb 14, 2008 | 12:29 PM
  #54
Inprogress's Avatar
Anyone know what spring initially comes in the hallman pro rx? Is it the softer one?
And is it difficult to change them out?
Old Feb 18, 2008 | 03:00 PM
  #55
a1091156's Avatar
Originally Posted by Skylineracer
I love my buschur inline MBC never had any spikes and it holds what i set it to.
What's the difference between it and the look-alike Perrin ?
Cost......? & Tag......?
Or actually design....
Ferp
Apr 19, 2017 07:58 PM
taylorgang
Nov 21, 2011 11:59 PM
06redMR
10
Nov 2, 2006 06:41 PM
silverEVO8
Jan 24, 2005 03:55 PM
ob4
Jun 15, 2004 05:51 AM
