question on trans case
Old Feb 16, 2008 | 11:33 AM
steevo 8's Avatar
got my car back from the shop a day ago and today i notice that there some t-case fluid on the ground so i jacked the car up and all the bolts are tight and doesnt look like its leaking for the seals. you can also see there is a bit on the down pipe. my question is, is there an overflow for the tcase or what?
Old Feb 16, 2008 | 11:41 AM
StevenStarke's Avatar
when u say the shop u mean like a local shop or the shop in CT? if its a local shop thats close to your house, maybe some was spilled and poured down a little but that sounds like a u have a leak from the t case seal
-Steve
Old Feb 16, 2008 | 11:47 AM
steevo 8's Avatar
no yea a local shop. and i dont think its spilled because there was no leak yest. just started today when i backed out of my friends drive way...
Old Feb 16, 2008 | 11:52 AM
steevo 8's Avatar
its a shep stage 1 T-case also 20 miles on it. now leaking?
Old Feb 16, 2008 | 12:14 PM
RazorLab's Avatar
If the shop fubared the seal between the tcase (which is easy to do if you aren't careful) and trans it can leak from there. It can also mix fluids and that is bad.
Old Feb 16, 2008 | 12:21 PM
Mike.p's Avatar
^^ yeah what he said..there are 2 o rings between the t-case and tranny...a big one and small one..if either of those get f'd up it will leak!
Old Feb 17, 2008 | 08:36 AM
steevo 8's Avatar
the morning after i noticed the leak and cleaned it off the day before
when i notice the leak the other day i looked under the car and this was all fluid that made it to the down pipe somehow.
this side of the tcase was also covered in fluid yest but i whiped it and it didnt start to drip again.
Old Feb 17, 2008 | 08:38 AM
turboDan's Avatar
Looks like Both axle seal may be leaking...
Old Feb 17, 2008 | 09:06 AM
cssaddictm4's Avatar
Doesn't look like the axles are seated fully...
Old Feb 17, 2008 | 09:33 AM
steevo 8's Avatar
it is T-case fluid tho correct? and also is it a problem that could have messed them up to where i would have to replace them. havent moved the car since i notice the leak and that was the day after i got it back...
Old Feb 17, 2008 | 10:49 AM
Either TC or Tranny fluid, both are red.
Old Feb 17, 2008 | 12:10 PM
steevo 8's Avatar
i thought the oem tranny fluid was white/clear?
Old Feb 17, 2008 | 12:16 PM
I may be mistaken on the stock fluids. I forgot that I use Redline fluids... Maybe someone can confirm on the stock fluids.
Old Feb 17, 2008 | 12:26 PM
Mike.p's Avatar
if that is redline fluids then that is t-case fluid..... the redline heavy shockproof is red kinda like peptobismal*(sp) and that is what you would use in the t-case.... so yeah i think the axles arnt seated all the way or the seals are bad....the shop was probably prying on the seals trying to pop the axles out
Old Feb 17, 2008 | 12:37 PM
From the picture it looks like a significant gap between the axle and transfer case.
