cams or upgrade to evo 9 turbo
Old Feb 21, 2008 | 11:37 AM
  #46
wshihdnevo's Avatar
Originally Posted by evo72man
Whats the difference between:
The old GSC V1 cams and S1 ? Someone wants to sell me the older GSC V1 cams 272/272.
Prob less lift and specs were changed. The newer versions I believe have more lift (correct me if Im wrong) are better for drivability compared to other cams such as hks etc. and basically make more power, but the old ones still make power, but GSC just made a better product and hence we have the s1.
Old Feb 21, 2008 | 01:48 PM
  #47
scheides's Avatar
EvoM Moderator
that's what I don't like about GSC cams, you don't know what version you are getting. With HKS you get 272's new or used, they are the same thing.
Again, I vote HKS 280's, I LOVE mine!
Old Feb 21, 2008 | 01:51 PM
  #48
Billy@EnglishRacing's Avatar
i would do cams first
Old Feb 21, 2008 | 01:57 PM
  #49
wshihdnevo's Avatar
You do know, most of gsc cams sold in the last year are the newer version I believe, but yes they dont say gsc on them or so i have heard.
  #50
jbeck's Avatar
Originally Posted by RevMoto
get yourself a set of GSC S1 cams. They make a much nicer power curve than HKS 272.
Old Feb 22, 2008 | 02:03 AM
  #51
EvoRecordSetter's Avatar
Originally Posted by wshihdnevo
Actually you are misinformed kind sir, b/c there are quite a bit of people on here running s2's on stock or stock appearing turbos and making power. GSC has alot more lift than most cams such as HKS etc. But there are other companies out there that have a crap tone of lift and dont recommend springs and retainers (side note). So to think that you know everything about it, just b/c that is what their website says w/out talking to Greg or anything isnt really a smart idea on your part. You are just as misinformed as you think everyone else is in this thread. On a different note I run the Buddy Club cams which are pretty much identical to hks specs. I have the 272/280 combo on a 6.5 TME and the car pulls like none other. I wanted to run the s1's and had thought about s2's, but got a smoking deal on these cams. If you want drivability, while still making a great power curve then gsc is the way to go.
wrong.
Originally Posted by Boltz.
S1 - Stock-GT30
S2 - GT35+
S3 - 1000whp+
Paul Nelson made 1000whp on S2's. Greg notes that the S2's work very well with a GT35R. S3's are custom grinds (I think) and are for those looking for 1000hp+
Edit; to answer your question, S2
GSC Power-Division Evo 1-3 and DSM S2 Camshafts
GSC Power-Division S2 cams for the Mitsu Evo 1-3 and first and second Gen DSM cars. The S2 cams are designed for those running larger turbo's 61mm and larger.Gains of 30-65whp (depending on Turbo) have been seen by simply bolting the S2 cams in. Designed for a rev range of 4000-9000rpms, upgraded...
https://www.evolutionm.net/forums/sh...light=gsc+cams
http://www.power-division.com/home.php?cat=266
like i said.
Old Feb 22, 2008 | 06:10 AM
  #52
STIKiller4G63's Avatar
Hey guys I have a guy wants to buy my stock camshafts...how much should I seel them?
Old Feb 22, 2008 | 06:15 AM
  #53
Soon2BEVO's Avatar
Get HKS 272/272 or HKS 280s or GSC 272s, nothing less, even with the stock turbo.
Old Feb 22, 2008 | 06:20 AM
  #54
4G63 T's Avatar
cams + tune
Old Feb 22, 2008 | 06:34 AM
  #55
Hey I just put in the 272 HKS cams they are good for daily driving but i heard my boy 280's am I must say I can def. hear a better loping while its idling but I did hear bad reviews about 280 HKS...I heard GSC is pretty good but my friend has 280 comp and i like how they sound they work great with his evo 8...to tell you the truth I would have got them...
Old Feb 22, 2008 | 06:37 AM
  #56
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
You have a 03 get the 10.5 hotside put cams in any to be honest with you 264/272, 272/272, GSC S1 it doesn't matter anything is better then the stock cam profile. Fuel pump, head studs if you care. Boost Pill.....hahaha get a boost controller like a man crank it up to 23psi and get it tuned you should make about 320-350 depending on oct and tune
Old Feb 22, 2008 | 07:01 AM
  #57
Well I am only pull 320 and I decided yesterday that I will get another tune and from somewhere else and slack on the evo 9 turbo....The tunner I am taking too looked at what maps I got on it now and promised me to give me a more aggresive tune and thinks I can do a lil more then 360
Old Feb 22, 2008 | 01:03 PM
  #58
MrNMrsEvo's Avatar
What kind of manifold at what psi?
Old Feb 23, 2008 | 12:51 PM
  #59
evo72man's Avatar
Ok, I am planning on getting 264/272 cams with adjustable cam gears and fuel pump.
I currently am dyno tuned for for tbe, drop in filter and boost pill. Can I drive around safely for a few days to a week after the cam install before I go back to my dyno tuner?
Should the cam gears be set at 0/0 initially?
Old Feb 25, 2008 | 01:08 AM
  #60
wshihdnevo's Avatar
^ask your tuner... or search for others setups on here, I know there are some threads floating around...
