Inside the Brian Crower 2.6L stroker...
Old Aug 3, 2009 | 07:29 PM
  #136
diablo2184's Avatar
bringing back an old thread......
Mr.Alex, hows the motor....are you happy with the Brian Crower setup still?
Old Aug 3, 2009 | 08:29 PM
  #137
Raceghost's Avatar
Damn!
Old Aug 4, 2009 | 12:04 AM
  #138
mr.alex's Avatar
Hey!
Yeah still going strong, not had too much time to drive it this year but have been on one trackday and covered some street. It's a pure monster when it comes to driveability.
Went streetracing yesterday and had a missfire that cracked my intake manifold
Old Jan 26, 2010 | 09:46 AM
  #139
sk8terdude929's Avatar
Bringing it back, what was the best 1/4 time you had? also at what max RPM and boost level
Old Jan 26, 2010 | 02:15 PM
  #140
mr.alex's Avatar
dont do steering-wheel-lock-racing, just track. Taking it to 7500rpms all day long
Old Feb 26, 2010 | 03:46 PM
  #141
miragevo's Avatar
Veteran: Navy
Have you upgraded your cams yet? Which cams did you go with?
Old Feb 26, 2010 | 11:42 PM
  #142
mr.alex's Avatar
Kelford 272/272 but not with any noticeable gains
My turbo was f*cked up so replacing it with a 6265 this year.
Old Feb 27, 2010 | 08:34 AM
  #143
High_PSI's Avatar
I am still unsure of the quality of this unit. 2.6 is HUGE, IDK how it can be practical in terms of safety. From what I know, Brian Crower stuff is outrageous, like shocking to get attention from buyers. My largest concern is the crank and 2nd largest is obviously the rod angels.
Old Feb 27, 2010 | 01:50 PM
  #144
miragevo's Avatar
Veteran: Navy
2.6L and FP Black!!!!!
How well do you think an FP Black would work with this 2.6 liter? AWD Motorsports just built a 2.4 liter 4G64 with FP Black combo that put out over 700 hp and 600 ft/lbs of torque and just ran 9.33 @ 146...wow!!! I was thinking of going ***** to the wall and build this in my spare time this summer. It would be the 4G64 with a Mivec head. I already have brand new GSC S2's and a bunch of parts I've been accumulating. I figured if I am going to build a 4G64, I might as well go as large as possible. I don't need to rev it to the moon on the street. I should be able to rev this set-up to 8000 rpm. I plan on using 156 mm rods, custom JE stroker pistons (9.5:1) with the pins moved up 9mm vs 6mm. This should give me a rod stroke ratio of 1.47:1 which is not too far off the 1.5:1 that the stock block 2.3 strokers are.....except I'll have 2550 cc's of displacement vs. 2324 cc's. This equates to a 21.68% increase in displacement over a stock 2 liter as well as massive torque down low to spool up the FP Black sooner than a stock turbo set-up. This sounds like a no brainer to me. Mr alex, do you still have the photos of the modifications that were needed to be done to the block to fit the 106mm crank? I can pm you my email address and maybe you could send them to me. Thanks and good luck with your 2.6.
Old Feb 27, 2010 | 01:57 PM
  #145
n2oiroc's Avatar
thats a pretty bad r/s ratio and the piston speed at 8,000 rpm is well past what most builders would suggest. 7,500 is about the most i would run.
Old Feb 27, 2010 | 04:28 PM
  #146
miragevo's Avatar
Veteran: Navy
I'll probably just bump the factory rev limiter up to 8000rpm and try to keep it under that and call it a day.
Old Feb 28, 2010 | 12:59 AM
  #147
mr.alex's Avatar
Interesting, I have told you before but I guess I have to repeat myself, the 156mm rods won't fit, that's why Brian went with 6" rods, but if you think grinding the bottom of the cylinders even more than I did is going to work then I aint stoppin´ya
Good luck, keep us posted
Old Feb 28, 2010 | 11:05 AM
  #148
miragevo's Avatar
Veteran: Navy
Mr.alex, Brian Crower now lists the BC6110 connecting rod on their website to go with the 106mm crank for the 4G64 2.6 liter. That rod equates to a 6.151" or 156.2354. Maybe they have seen it work in the field...you would hope. I remember you telling me about the grinding of the block to make it work, but when I spoke to BC they were initially concerned about the compression height where you would have to shift the pin up 9mm instead of 6mm. There are plenty of people running these custom pistond at 9mm up and they are holding the power without any problems. Manley Performance actually makes a stock 156mm H-beam and a piston with a 1.012" compression height for example. I guess I won't know until I try it. I would assume that the BC7110 piston that sells with the 2.6 liter kit from Brian Crower would have a similar compression height around 1.012". Thanks for the pictures. BTW, do you recall where exactly on the connecting rod did it make contact with the bottom of the bore and how much did you have to remove? Do you have any picture of what it looked like after you were done grinding the block? Thanks
Old Mar 1, 2010 | 12:53 AM
  #149
Chris Fisher's Avatar
Chris Fisher
Very nice of you. Thanks!
I hope all the machining and tolerances are correct so we can put this bad boy on the road. Chris Fisher
Old Mar 1, 2010 | 02:58 AM
  #150
project_skyline's Avatar
If you think the 2.6 is going to be reliable with any high amount of power and/or rpm's your outta your mind. Not only is it made by BC but it takes the engine to its absolute limits both physically in the block and the components.
