My AMS 2.3RR 37R Build
I'm a bit surprised to see such high numbers from a DD dyno. They are supposed to read a good chunk lower than a Mustang. In the UK there is several results of engines coming off the engine dyno, and onto a DD chassis dyno, and generally there is a 24% loss from flywheel to the wheels.
That means 520 hp DD should be 684 at the crank. Although, this is a 37R so actually maybe that is pretty close. Many 35R's in the UK do around 600 at the crank on pump, so a 37R should do more, so I think actually this does make sense.
Just to back the underdog... I will bet on this car versus a BR car on pump
BlueByYou... will you make it to the track on pump soon? And if so, are you a good driver?
For comparison, a friend of mine with a VIII with boltons just dynod at Forged and put down 220whp... Another comparison, my previous setup was a cammed FP Green on methanol And I only hit 352 on this dyno. This is part of the reason we aare so curious to see what this car does on a mustang dyno and a dynojet.
Yep most stock turbo cars in the UK will never put down more than 300 atw tops on a DD which is pretty much the only dyno used over there. Which equates to about 400 at the crank, which is great power for a stock tubo.
Sharif is the first DD operator in the USA out of many that when I asked about Shootout mode said it reads the same as the mode he normally runs the dyno in. All the DD operators in the UK, and I mean every single one, do power graphs for customers in Shootout mode which shows all the details of the run which could effect power.
BlueByYou.. you should go to the track and just roll out of the hole and see what you trap. Would be interesting. I think you will do very well against the Buschur cars.
Honestly, at this point we have no idea how Buschurs Mustang dyno reads compared to Forged's Dynamics. So basically, as far as numbers go its a guessing game when trying to compare numbers. We simply would like to put your car on the dyno make a few pulls and see how it reads. Obviously temp, humidity, ect. may be different from when you dyno'd at Buschur, but we would just like some kind of comparison so we dont have to guess how we are reading compared to everyone on Mustang dyno's and Dynojets. I hope that sounds acceptable to you.
l8r)
Here is an example for you... many very stock cars run like 1.3 bar (19 psi) from the factory. Then people add a few mods and run like 22 psi or so. Now don't you think when you go to a 37R and massive intercooler you'd be able to run a good chunk more boost? The compressor is more efficient at higher boost levels in the 37R than the OE turbo, the hotside is larger so less back pressure, the intercooler is much better, etc... all of those things mean you can run more boost from the theory I understand.
But anyway, sorry for the off-topic... good luck getting the car ready for the track BlueByYou! Make sure to check your oil often, keep a close eye on everything under the car as it's a new build.
You should bring the car up here for the DSM/EVO Shootout next month. It's a great time and you can throw it on our dyno if you like. The shootout is a blast, you can't go anywhere else and get this many Mitsubishi's all in one place.
Come on up, you'll have a blast.
Keep in mind, this guys claims he is "expected" to run 9.2-9.3 his first time out and get booted off the track.
your lucky my car wont be ready by then. I think I would give you a run for your money. Car should run low-mid 9's -_-
Just get your car fixed Blowinbluesmokeupthewazzu and we'll setup the race.
Originally Posted by BlewByYouEvoVIII
lol ya, funny part is, if I get the numbers I think I will in addition to the gains with the Tomei 280s then its possible I may break 800whp, lol! But I dont want to get ahead of myself quite yet. I need to upgrade the axles before I do any drag runs, and its highly possible that I will get kicked off after my first pass because Im expected to hit around 9.2-9.3 with a good launch with this setup... lol
your lucky my car wont be ready by then. I think I would give you a run for your money. Car should run low-mid 9's -_-You should bring the car up here for the DSM/EVO Shootout next month. It's a great time and you can throw it on our dyno if you like. The shootout is a blast, you can't go anywhere else and get this many Mitsubishi's all in one place.
