My AMS 2.3RR 37R Build
Even as the car sits Im sure I would hit that, which would in turn get be booted off. Why dont you lay off and stop hating on my build.
Roll bar at 11.99 (NHRA) and 11.49 (IHRA) is what it used to be. Then in 05 the NHRA changed it to 11.49 also. If something has changed since, I apologize.
Back on topic: The car sounds sick, hopefully you make it to the shootout.
I do not expect to run 9.2 my first time out, stop twisting my words. When the car is done I would like to be able to hit those times, but it will take quite some time before the car or I am able to hit those. If you have ever been to the track yourself you would know you get kicked off the track for running 10s
I simply quoted you from another forum stating you were "expected to run 9.2 your first time out".
You don't get kicked out at Silver Dollar Raceway, people run 8's there with no roll cage. I ran 11.1 @ 123 on pump gas with no cage.
Waiting on you....
I never stated that I would be hitting those times my first time out, I was merely saying I expected to get kicked off my first time out. I would appreciate it if we could end this debate. I really dont see any good things coming out of this argument.
Good to know. Ill have to figure out how much it is to tow the car up there, since I am not wanting to put any unnecessary miles on the car. What is the exact date of the shootout again?
August 16-17th.
Here's a link with all the details. From the sounds of all the people calling and such it is going to be the biggest event ever.
http://buschurforums.com/forum/showthread.php?t=20243
August 16-17th.
I was able to ride shotgun in Ryan's car this past weekend at the Nashville Redline Time Attack with Robert Fuller behind the wheel - This car is stinking FAST! With virtually stock brakes and suspension, Robi was able to pull a 1:09 seconds... that time if Ryan had a catt would have taken first place in Street class, but had to run in Modified and still took second place!
On the way to the track, Ryan and I did a little 70-145mph run (I was in my TT G35 running wastegate, 14psi and pump gas) and it was the closest race I've ever had, we were basically bumper to bumper the whole run with neither of us giving an inch! This was all done on a closed course, no street racing
hey man i saw you and your car in the pits. It was just immaculate and put together very well. also congratulations on your placing. I wanted to take my car on the track but i was trying to sell it.
, Im not sure of the exact number, I just know regardless I am going to need a cage
