F%$& lots of damage to MOTOR???
Old Mar 8, 2008 | 08:40 AM
  #61
jamerin's Avatar
Originally Posted by gsnt
Thats a perfect example of "Staying in it!!"
+1
Old Mar 8, 2008 | 08:44 AM
  #62
wokuku's Avatar
Should change your head gasket while you are fixing it
http://jdm-insider.com/Blogs/Eric/?p=386
Old Mar 8, 2008 | 09:09 AM
  #63
BigBallin's Avatar
hope it works out for you
Old Mar 8, 2008 | 09:20 AM
  #64
itzwolf's Avatar
Teddy,
Go with a stock head gasket this time. It's much better than the one you had. All the big shops use stock head gaskets, even on shop cars with big horse power.
Old Mar 8, 2008 | 09:36 AM
  #65
DG Motors's Avatar
Originally Posted by boostGotMeLaid
oh my god what the i hope not gezzzz thats like strait melted what happen how did it happen
too much timing, boost, and knock
you live and learn.
Old Mar 8, 2008 | 10:15 AM
  #66
Jeff_Jeske's Avatar
Once you replaced the spark plugs..... how did the car idle?
Old Mar 8, 2008 | 12:27 PM
  #67
boostGotMeLaid's Avatar
idled the same missing like a bad bish
Old Mar 8, 2008 | 12:40 PM
  #68
pics will be up tonight pistons pretty rocked dropping the oil pan as we speak Chris@nolimits is doing his best helping me out getting just one.
sending rod out for inspection hopfully its not bent Eagle FTW in my book things could have been alote worse, if i knew i was going for bigger power i would go with Crower but the Eagles will do just fine with my setup n plans...BUT like they always say this **** is addicting and cant have just some u want it all.
Old Mar 8, 2008 | 12:42 PM
  #69
Originally Posted by itzwolf
Teddy,
yup will be returning stock... What are u using for timing belt stock right??
Old Mar 8, 2008 | 03:25 PM
  #70
itzwolf's Avatar
Stock timing belt is what I use, and recommend it.
If your rods turn out to be bad, Crower rods would be WORTH the insurance. They are much better than Eagle rods.
Old Mar 8, 2008 | 03:59 PM
  #71
Old Mar 8, 2008 | 04:04 PM
  #72
i need to say wow just looking at those pics again but theres minor scratchs on the walls but nothing serious
Old Mar 8, 2008 | 04:36 PM
  #73
ExViTermini's Avatar
worst camera of the year award right there. Can you take a further away shot of the piston? Up close it gets blurred.
Looks as though lots of heat in the cylinder or something got stuck b/w piston and cylinder.
Old Mar 8, 2008 | 04:39 PM
  #74
i know worst camera its taken by my iphone sorry about that
Old Mar 8, 2008 | 06:04 PM
  #75
edit
