evo green manifold options
Old Apr 16, 2008 | 02:00 AM
  #46
justevo's Avatar
Originally Posted by RevMoto
I have read the test. I have also seen all designs of evo manifolds. The full-race design isn't that far off from a megan. Only difference as stated above is that it is the quality of a manifold that makes the price. Yet the megan did horrible that buschur said and the full-race did the best. I have also seen better gains on my borla compared to my stock ported than what david got comparing the full-race to ported. I am not saying the Full-race is crap. I am saying it is not the best manifold. It is the best quality though.
Hey, Why you are trying to push Borla manifold, even the manufacturer itself declared that this manifold not designed for evo9 and he will not provide any warranty if it used on EVO 9.
Old Apr 16, 2008 | 04:25 AM
  #47
afmafia's Avatar
i like the mynes version 2 manifold for the money
Old Apr 16, 2008 | 03:39 PM
  #48
funnyclub's Avatar
I run a Mynes manifold on my green.
It is a quality manifold and it looks great
Old Apr 16, 2008 | 03:51 PM
  #49
RevMoto's Avatar
That is just a ridiculous comment. An 8 and 9 manifold are the same thing. Where did you see that. Plus I am not pushing any manifold. I have tested a lot of manifolds made for the evo and this one has made the most power. The quality of the borla is horrible which surprised me since the headers I had from them on my Trans Am looks so much better. I am having my manifold duplicated with the same piping used by fullrace.
Old Apr 16, 2008 | 04:01 PM
  #50
krispytapa's Avatar
what gas will you be using? just use a ported stock manifold.
Old Apr 16, 2008 | 04:05 PM
  #51
Vivid Racing's Avatar
I have the JIC on my evo it cracked when I used header wrap. Just rewelded it and its fine now. For the downtime I used a PPI ported manifold and it worked great!
Tubular feels like it gives you more top end than stock. + it sounds better IMO
Cast ported feels more tq down low than stock.
At the end of the day op whats your budget?
PPI does amazing work and would recommend them for porting. This is by far the most affordable.
When it comes to tubular they will crack unless the thicker stuff is used. It all depends on when. If you use the Invida 02 it uses the factory mounting to the block so it helps prevents a lot of the vibration that causes the cracking. Either way its up to you. I wish you luck!
Evan Smith
Old Apr 16, 2008 | 04:14 PM
  #52
shunderwunder's Avatar
I also have a Mynes manifold with my stock turbo. The quality is top notch.
Old Apr 16, 2008 | 04:15 PM
  #53
SME's Avatar
SME
I would say stock ported or mynes!
Old Apr 16, 2008 | 04:25 PM
  #54
stock ported is definately the best bang for the buck, but looks was a factor for me so tubular was th only option. They aren't cheap, but you get what you pay for.
Old Apr 16, 2008 | 06:00 PM
  #55
David Buschur's Avatar
This is not to start an arguement, I am just going to point something out. There are (6) EVO's that have gone 10's on the green, that I know of. All of those but one had a stock ported exhaust manifold on them. If my memory is correct the one that didn't used a DC Sports header, it cracked.
Anyway, maybe they all had ported stock because all of them were directly related to our shop and that's what I suggest. Point is they work, they are reliable and they are cheap.
Old Apr 16, 2008 | 06:09 PM
  #56
RazorLab's Avatar
Here is stock cast manifold VS. a Megan manifold with a FPgreen on a Evo 8:
As you can see it lost a bunch of spool with the Megan manifold, and after that both where pretty much the same.
I had a Evo 8 with a JIC tubular manifold on the dyno 3 weeks ago. The manifold cracked 40mins into the dyno tuning session.
Old Apr 16, 2008 | 06:10 PM
  #57
RevMoto's Avatar
I completely agree with you. I port our manifolds all day. They are not the best performing manifold though. Also definitely not the best looking too.
Old Apr 16, 2008 | 06:27 PM
  #58
Looking at razorlabs dyno sheet it looks like we got about the same results. The stock one spools the fastest of anything and if I am guessing right as the chart is hard to read, even uptop the stock one makes a few more HP. The Gtspec we tested is very similar to most other headers out there in design and the results looked like the Meagan from above.
revmoto, other than the Full Race the stock ported/coated manifold outperformed all others we tested. The Full Race made more power up top. Nothing I have tested has beaten the stock manifold under 5,000 or so RPM.
Old Apr 16, 2008 | 06:33 PM
  #59
RazorLab's Avatar
david,
yea sorry I didn't do dotted lines for the other curve. The Megan made a little more power up top (3whp peak), but not enough in my book to warrant the loss in spool.
Old Apr 16, 2008 | 06:36 PM
  #60
MyEvoRocksUrv8's Avatar
How much more did the Full-Race make up top compared to the stocker? Also...does anyone know how the Mynes compare to the two?
