evo green manifold options
You also have to look at boost onset and where boost is at in reference to rpm between the two. I know I noticed a difference but then again I've never ran a ported stocker on my green. I also got the megan for less than one though. Hasn't cracked yet(knock on wood) but we cleaned it up a good amount and did some reinforcing before it went on. I think for a stock turbo car it's slightly more of an advantage running a ported stocker over a well designed tube header. Only ones I'd ever buy if I was actually spending more on it would be a full race used and I like the mynes just because they still have somewhat of a collector.
Looking at razorlabs dyno sheet it looks like we got about the same results. The stock one spools the fastest of anything and if I am guessing right as the chart is hard to read, even uptop the stock one makes a few more HP. The Gtspec we tested is very similar to most other headers out there in design and the results looked like the Meagan from above.
revmoto, other than the Full Race the stock ported/coated manifold outperformed all others we tested. The Full Race made more power up top. Nothing I have tested has beaten the stock manifold under 5,000 or so RPM.
Mike, a.k.a. mwbmw, can either one of the two Mynes manifolds be ordered flanged, for a remote gate? If so, then which of the two is best suited to clearance a downward pointing VTA remote gate on an Evo?
This is a generalization; while Full Race is a well built manifold, they've not been tested superior for every manifold they make.
Mike @ Mynes
razorlab, OK, that explains it, had it been ported..............I don't think you'd have seen any losses compared to that header anywhere in the curve.
revmoto, I must have missed something. Did I say anything about trusting or not trusting a log in this thread? Not that I do.
awww you changed it
