power steering
Old Mar 4, 2008 | 08:21 PM
Epidemic's Avatar
power steering
What makes it whine? Mine has been doing this for some time I replaced the powersteering pump and it was still there. If i remove the accessory belt it goes away, so I used the stethoscope and the noise is coming from the powersteering pump... Anyone have this powersteering wine and if so whats the fix?
Old Mar 4, 2008 | 08:23 PM
2k4EvoVIII's Avatar
Low on fluid!
Old Mar 4, 2008 | 08:24 PM
idriveanevo's Avatar
usually thats a sign of low fluid, or air in the line. i know that on a subaru, you have to bleed the system of it will ruin the pump... not sure about our cars tho
Old Mar 4, 2008 | 08:34 PM
2k4EvoVIII's Avatar
It bleeds itself on our cars from my experience.
Old Mar 4, 2008 | 08:43 PM
Epidemic's Avatar
i did bleed it
Old Mar 5, 2008 | 02:24 AM
C6C6CH3vo's Avatar
To bleed it you got to lift the front tires off the ground, disconnect the crank sensor, and turn the starter several moments while turning steering wheel full left and righ checking for fluid level and bubbles.
If that doesnt help try free spinning it to see if it binds.
it is normal to have mild whining at higher rpm
If your idle is too high it will normally be a little noisy
Old Mar 5, 2008 | 05:56 AM
Epidemic's Avatar
The wining makes my car sound like its supercharged lol it has been like this for a about a year and a half. That is how I bleed it c6c6ch3evo... I want to eliminate the powersteering because I cant figure this out. Maybe I can get some people to chime in. Chris from ams heard it and was worried about the noise the first time he tuned my car. The noise is still there and and the car has no problems driving fine. The car has seen days at the track like this with no problem.
Old Mar 5, 2008 | 06:17 AM
Epidemic's Avatar
I will post a video of it later on maybe that will help things out.
Old Mar 5, 2008 | 06:19 AM
sharkm87's Avatar
maybe..second pump bad as well?...you purhcased a brand new one?
Old Mar 5, 2008 | 06:23 AM
evospecialist's Avatar
you can bleed it by just starting the car wheels on the ground and turn it lock to lock no need to jack the car up and turn the starter and disconnect sesnors of any sort start the car turn it lock to lock and until the noise is about gone check the fluid for bubbles and top it off should be good unless you have another bad pump or the wrong type of fluid.
Old Mar 5, 2008 | 06:39 AM
Epidemic's Avatar
Yeah i got a brand new one from mitsu even tried a friends spare one wine goes away for a min then is back.
Old Mar 5, 2008 | 06:44 AM
sharkm87's Avatar
maybe somethin is loose
Old Mar 5, 2008 | 07:00 AM
you might have a bad o ring on one of the pump lines all you would have to do is is find out witch one it is replace the seal and blead the system. it has air in it.
Old Mar 5, 2008 | 10:28 AM
C6C6CH3vo's Avatar
Yeah, something in the system besides the pump itself.
It is a tinny whine, right?
I thought bleeding it with pump and car on, with car on ground makes tiny bubbles
magyar86
For Sale - Part Outs
Jan 10, 2016 09:48 AM
05raslw
13
Oct 23, 2012 02:21 PM
pinoy6969
Dec 27, 2011 08:23 PM
SilverEvo8owner
Oct 5, 2010 12:58 PM
AOR
Mar 8, 2004 11:56 AM
