What springs and retainers for gsc s2's?
Old Mar 13, 2008 | 06:09 AM
AKgambler47's Avatar
Can anyone help me with what valve spring and retainers to get, and what head gasket. The cams are going to be gsc s2's on stock turbo, but a 35r or 37r is in the future. I dont want ti and want to stay around 250 for the springs and retainers. Preferably dual's. I am getting arp headstuds, and most likely a cometic headgasket unless someone says otherwise.
Old Mar 13, 2008 | 06:22 AM
mymigi's Avatar
stick with OEM headgasket....and with s2, you might want to do singles and keep it under 8000-8500 rpm, anything higher and i would definitely go with duals.
Old Mar 13, 2008 | 06:57 AM
Burklow's Avatar
+1 on OEM headgasket.
Old Mar 13, 2008 | 07:17 AM
Ev0cRaZy's Avatar
Stock Headgasket
I have supertech dual valve springs and retainers with my S2's
Old Mar 13, 2008 | 07:30 AM
Ambiguous's Avatar
Any Plans for a built bottom end to get the most out of your future 35R or 37R?
Old Mar 13, 2008 | 07:36 AM
No not right now. First is cams, then fmic kit,clutch and flywheel, mainly parts that will hold lots of power. Then that is when that stuff is going to be done. Staying 2.0 though.
I am set on arp headstuds,cometic or oem head gasket(idk yet) and gsc dual valve springs and Chro-Molly Retainers. Getting gsc's because the cams are gsc, should fit together perfectly
Old Mar 13, 2008 | 07:50 AM
Ev0cRaZy's Avatar
OEM Headgaset, threre is a lot of threads with people having problems with cometic.
Old Mar 13, 2008 | 11:40 AM
caLi4G63's Avatar
brian crower valve springs and retainers should be good for anything under 9000rpms; i don't think you'll be going that high anytime soon and they are within your budget range.
Old Mar 13, 2008 | 12:39 PM
Whoop_ass's Avatar
OEM headgasket....
that is what buschur and AMS use, and they run 40psi
Old Mar 14, 2008 | 04:24 PM
moses evo's Avatar
manley titanium retainers and springs , awesome piece of kit
ayoi
29
Dec 4, 2018 06:17 PM
ChicagoEvo9
48
Feb 24, 2017 02:21 AM
ineedboostman
10
Oct 19, 2016 02:59 PM
Black_EVO_MR
Jun 3, 2016 08:37 AM
justa4banger
Jul 10, 2009 12:12 PM
