6-speed MR clutch in a 5 speed?
Old Mar 16, 2008 | 02:49 PM
ACTman's Avatar
Aftermarket ones are the same, even though the stock discs may be a tad different.
Old Mar 16, 2008 | 03:00 PM
fromWRXtoEVO's Avatar
They should work just fine. at least 3 years ago someone posted the picture and did a write up. The main diference between the MR clutch and the 5 speed was the lenght of the springs within the disc being the MR longer thus giving you a smoother feel on the pedal.
I have a entire clutch/flywheel of a MR seating in my garage.
Carlos
Old Mar 16, 2008 | 03:02 PM
Boostfiend's Avatar
Originally Posted by dpacific
It might work between both but, just makes me laugh because if you shift in into 6th what will happen? lol
lol @ you loling and then getting lol'd at because you lol'd. LOL!
Old Mar 16, 2008 | 04:12 PM
dpacific's Avatar
? Wow lotta homo stuff going on in this thread. So if you have a 5 speed tranny and a 6 spot your shifter and throw into it, wtf is going to happen nothing? just go into neutral?
comprehension is a little off..
Old Mar 16, 2008 | 06:08 PM
RichC's Avatar
Why would I suddenly have a 6th gear on my shift knob? Do you even know what a clutch is?
Old Mar 16, 2008 | 06:10 PM
ChuckP's Avatar
Someone might be able to answer that if you retype it..
Old Mar 16, 2008 | 06:12 PM
Billy@EnglishRacing's Avatar
you will have no problems
Old Mar 16, 2008 | 06:15 PM
t51splbb's Avatar
Dirk, the only exception to that I think would be the Fidanza kits that only work on the 5 speed and not on the MR from what I've heard.
Old Mar 16, 2008 | 06:24 PM
ACTman's Avatar
The disc is the only difference between the MR and the XIII. I have no idea about the Fidanza parts, but if a company is choosing to use the Exedy WAD (wide angle damper) design (stock MR) for performance use, I would be concerned.
Old Mar 17, 2008 | 03:32 AM
dpacific's Avatar
thats the thing that makes the pffft sound right?
Old Mar 17, 2008 | 09:16 AM
andrewzaragoza's Avatar
for those who don't know here is how a clutch works http://auto.howstuffworks.com/clutch.htm
hope this helps.
Old Mar 17, 2008 | 04:51 PM
RichC's Avatar
No need to get silly now.
It seemed that you thought changing the clutch also meant changing to a 6-speed shift knob? Is that what you did? What you wrote made absolutely no sense and had everyone either scratch their heads, or LOL.
I expected more from you, even after I saw that you had started your own little clutch thread some time ago.
Old Mar 18, 2008 | 10:39 AM
dsevo's Avatar
You cannot possibly be serious. If so, you have demonstrated a new level of retardation I have never witnessed. The best part is you're still arguing about it.
Old Mar 18, 2008 | 10:46 AM
dpacific's Avatar
Whats the point in bumping this thread today?
It was already expressed that i stumbled on his words wrong.
for some reason i looked at it quick and responded quick. thinking that putting the clutch from a 6 speed in would make a 6th slot for the shifter. I'm LOL at my self now
Old Mar 18, 2008 | 06:57 PM
RichC's Avatar
PeteyTurbo
205
Dec 10, 2024 06:04 AM
Evo_7
Feb 11, 2011 07:58 AM
ToMuchBoost
May 15, 2010 10:41 PM
vince_w2004
Apr 19, 2010 01:15 PM
MR_EVO21
10
Jul 18, 2007 02:24 PM
