Tial Wastegate spring question
Old Mar 27, 2008 | 07:46 AM
sabastian458's Avatar
I am really confused here, and hopefully someone can better explain it to me.
When trying to run higher PSI, you are suppose to double up the wastegate springs (1 small spring + 1 large spring = Total PSI) Well my confusion comes in at this: If you double the springs (a 1 BAR spring and a .5 BAR spring) when the PSI reaches the 1 BAR pressure, wouldnt the PSI over come both springs at 1 BAR not 1.5 BAR?
Old Mar 27, 2008 | 03:03 PM
help anyone?
Old Mar 27, 2008 | 03:42 PM
Max Power's Avatar
Nope... you combine the springs. With just the big blue I was boosting to 14 psi. Added the little green and went to a gm 3 port bcs and it is at 21 psi of base spring pressure.
Old Mar 27, 2008 | 04:40 PM
ok, I just wanted to make sure. It just didnt make sense to me. thanks
Old Mar 27, 2008 | 05:00 PM
DSMu4ia's Avatar
Tial 44 .PDF
http://www.tialmedia.com/documents/w3_tial_44_sp.pdf
Old Apr 4, 2008 | 06:21 AM
Guz Man's Avatar
question about that though.. what size/color spring does the tial 44mm come with by defualt?
Old Apr 4, 2008 | 06:23 AM
TiALSport's Avatar
there is no default, they are built by order
Old Apr 4, 2008 | 06:33 AM
Guz Man's Avatar
ahh.. ok.. thanks..
KingTal0n
Nov 27, 2016 05:23 PM
ghad
May 25, 2014 02:27 AM
boonkae
18
Jul 17, 2011 04:26 AM
Smogrunner
Apr 5, 2007 03:07 PM
TrinaBabe
Jul 23, 2005 03:07 PM
