Uicp pipe help
Old Apr 7, 2008 | 11:51 AM
evotuner04's Avatar
15 Year MemberLikedLoved
Uicp pipe help
I bought a br uicp and it has meth/alky hole tapped and im not gunna run meth for a lil while and was wondering if i can just plug the hole? or what else could i do?
Old Apr 7, 2008 | 12:14 PM
RevMoto's Avatar
Is it threaded? I can't tell form the picture. Either way a bolt nut and of course a washer. Some might say JBweld also but idk how good that will come off.
Old Apr 7, 2008 | 12:18 PM
evotuner04's Avatar
i just bought it so i wont have it til the end of the week im assuming....could i just plug it with some sort of grommet or would that blow out
Old Apr 7, 2008 | 12:28 PM
Brian's Avatar
With the thickness of that, even if it was threaded I wouldn't expect it to hold up. If you're going to plug that you're likely going to need to weld a bung on it then plug it.
Old Apr 7, 2008 | 01:57 PM
gvr4737's Avatar
you could plug it with a grommet if you are gonna run maybe 3psi...
think about that.. grommet. not made to hold 18psi
just thread it and use an 1/8th inch pipe plug.. same thread/plug ud use for an egt gauge
Old Apr 7, 2008 | 03:19 PM
urslo4n8's Avatar
Ok. This is definetly NOT gona look great but you can cut o small piece of hose then clamp it around. Thatl def hold but may not look so great.
Old Apr 8, 2008 | 07:08 PM
evotuner04's Avatar
ahh **** ill just wait til i get the meth system lol
Old May 25, 2008 | 03:48 PM
evotuner04's Avatar
ok so im not getting meth anytime soon so should i weld something over the hole? and re-tap it if i ever need to? or thread it and put a pipe plug in it like stated above?????
Old May 25, 2008 | 03:54 PM
Indy Evo's Avatar
Sent it to Buschur and have Trent weld a bung into it. Then you can plug it and when your ready remove the plug to go with meth. Brian H's answer is the only right way to do it.
Old May 25, 2008 | 03:56 PM
Shacochis06's Avatar
does all of buschurs uicp come like this?
Old May 25, 2008 | 03:57 PM
Indy Evo's Avatar
no
Old May 25, 2008 | 03:59 PM
evotuner04's Avatar
^no, but i dont think im gunna run meth.....im gunna save up for a gt35r and run pump and race gas but mainly just 93.....so what would be best to do then for the uicp
Old May 25, 2008 | 04:07 PM
Indy Evo's Avatar
If you have them weld in a bung you can always ues it later the other fixes are just band aids.
EvoEi8ht
Mar 12, 2015 11:14 PM
chris89
Jul 7, 2011 04:58 PM
BCOZEVO
Aug 10, 2008 10:10 AM
YNGEVO
96
Aug 8, 2008 10:07 PM
1mbrews8
ExtremeTurboSystems.com – WA
Oct 16, 2007 03:00 PM
