engineers please answer
Old Apr 9, 2008 | 03:47 PM
lemmonhead's Avatar
to all engineers out there here is a question to you.
do you think something vibrating on a turbo compressor side can cause turbo seal, bearing premature failure?
Old Apr 9, 2008 | 03:56 PM
runuts's Avatar
Well if the comp wheel is vibrating, then so is the exhaust side, and the whole shaft, including the bearings etc. So absolutely.
Old Apr 9, 2008 | 04:23 PM
gsrboi80's Avatar
Uhh yea man for sure
Old Apr 9, 2008 | 04:26 PM
spumoni1984's Avatar
definitely. generally things aren't build to vibrate-that's why there are dampers on your car (not to be smug)
Old Apr 9, 2008 | 04:27 PM
justboosted02's Avatar
yep
AndyBandy's Avatar
definitely
Old Apr 9, 2008 | 05:00 PM
bhennesy's Avatar
si senor
Old Apr 9, 2008 | 07:25 PM
KevinD's Avatar
ja, das ist nich so gut
Old Apr 9, 2008 | 09:54 PM
sparky's Avatar
Your turbo´s rotor group which consists of the 2 wheels and shaft should rotate in a perfect circular motion about the shaft centerline. Vibration whether caused by excessive shaft runout, individual component imbalance or rotational imbalance of the complete rotating assembly would result in an elliptical rotation, creating gaps in the seals allowing oil bypass eventually resulting in premature turbo failure.
crf inc.
May 24, 2026 03:03 PM
johnnysixer
17
Apr 25, 2005 05:15 PM
Rau
Mar 30, 2005 12:46 AM
Jaxice
Oct 1, 2003 09:05 PM
