Car Fluid Alternatives
Old Apr 10, 2008 | 12:15 PM
DesertEvolution's Avatar
My Evolution IX GSR just hit 30,000 miles. I'm gonna perform the manufact. Scheduled maintaince for the car. I called Mitsubishi to ask what other fluids I can put instead of their Mitsubishi Diaqueen fluid. They told me it can only take that fluid just to get my business but I would like to upgrade the fluids. Any suggestions?
Old Apr 11, 2008 | 11:15 AM
Davo's Avatar
there are many threads here
basically ensure u get a GL-4 for the gear box and a GL-5 for X case and rear diff
also ensure the GL-5 is an LSD approved oil or u would hear chatter from it
Popular choices are Redline, Mobil and Amsoil(what i use)
Old Apr 11, 2008 | 11:32 AM
UT_Evo's Avatar
Almost everyone will tell you to use only the Diaqueen in the TC, TRE told me to put only that in mine after they built it.
As far as everything else, anything goes as long as it is under mfr ratings. I used 10w-30 redline oil for awhile, then decided it was a waste and used (still do actually) mobil 1 10w-30. Tranny I always used Royal Purple.
Old Apr 11, 2008 | 12:00 PM
newbieEVO8's Avatar
You can never go wrong with the OEM fluid.
Old Apr 11, 2008 | 01:29 PM
matt55's Avatar
AMSOIL , "oil doc" on here will help you out .
Old Apr 11, 2008 | 02:46 PM
chaotichoax's Avatar
diaqueen in the xcase and rear diff
the tranny is debatable but since you can't get oem tranny fluid from mitsu in a small size usually people go aftermarket (unless you get "MR" tranny fluid) which you can use in a five speed some have said it makes shifting even better
just something to consider
Old Apr 11, 2008 | 05:57 PM
barneyb's Avatar
I went to the dealer and bought the bucket their technicians had been using from. That is a smaller size although the size may vary!
Old Apr 12, 2008 | 03:34 AM
EvoMike's Avatar
Veteran: Air Force
Recommended by John Shepard at ShepRacing.com/ShepTrans.com
Redline MT-90 in the tranny
Redline Heavy Shock Proof in the x case and rear diff
(Mr. Shepard also recomended oem Diaqueen as a solution)
I've been running the above listed Redline products respectivley in both a "Shep Built" tranny and t.case w/ Quafe LSD.
Old Apr 16, 2008 | 07:44 PM
Oil Doc's Avatar
They don't even know who makes their fluids... If asked, I'd bet most would say "Mitsubishi makes Them" ... Fact is, they go out for bid every few years to the lowest bidder.
If you want the best, contact me. I have packages worked up for complete fluid changes..
Doc
Old Apr 16, 2008 | 09:20 PM
red evo8's Avatar
tranny = redline mt90
tc= diaqueen
hands down
Old Apr 18, 2008 | 07:58 AM
Oil Doc's Avatar
AMSOIL SSO or ATM.... Engine
AMSOIL MTG................ Tranny
AMSOIL SVG................ TC and Diff
Doc
Old May 30, 2008 | 03:47 AM
gizzmo's Avatar
If you want notchy gearchanges when the gearbox is cold put mt 90 in your car
Old May 30, 2008 | 04:05 PM
Oil Doc's Avatar
You got it. I have switched quite a few EVO owners over to AMSOIL MTG with Fantastic results, Warm and Cold
Doc
Old May 30, 2008 | 04:09 PM
gsrboi80's Avatar
Ive only ever used OEM DIAQUEEN in the Rear and TC
Penzoil Syncromesh in the tranny
100k miles strong still shifts like butter. I change all fluids every 6k-8k
Lucas Mendoza
Aug 22, 2017 07:01 PM
MagnumVP
Lancer Tranny/Drivetrain Tech
Sep 5, 2011 10:51 AM
sk8elenex92
Jul 19, 2010 06:28 PM
EVO-L-OV3
Sep 30, 2008 09:58 AM
Mitsu_Evo_MR
Mar 24, 2008 06:44 PM
