ets 3' or 3.5'?
Old Apr 12, 2008 | 11:28 PM
turbogst311's Avatar
ets 3' or 3.5'?
Hey guys, I have an evo 9 se and im looking to buy a fmic asap. Im running a stock turbo with bolt ons. (exhuast/intake/02 housing. test pipe. fuel pump. boost controller. I want to see other opinions on what size fmic to get. Im going to upgrade turbo but not this summer. Probably towards end of year. I need feedback please guys =) 3 inch or 3.5 inch.
Old Apr 12, 2008 | 11:36 PM
Wicked E's Avatar
5"
Old Apr 12, 2008 | 11:37 PM
vvhiteix's Avatar
either or...maybe Tom can chime in. : )
Old Apr 12, 2008 | 11:53 PM
RoadSpike's Avatar
What turbo do you plan to run?
If weight and cost is not an issue just get the larger one the greater surface area should reduce back pressure resulting in some gains though perhaps marginal gains.
Old Apr 12, 2008 | 11:55 PM
recompile's Avatar
The smaller the core, the faster your spool will be.
I recommend the 3" for under 400whp... you won't heatsoak that unless you are hotlapping on a 100° day
Old Apr 12, 2008 | 11:56 PM
90GSX-03EVO's Avatar
Their 3" works great for me. It'll work fine unless you're talking about upgrading to a GT42 or something.
Old Apr 13, 2008 | 09:10 AM
Thanks for the feedback guys. Im going to order the 3'
Old Apr 13, 2008 | 09:51 AM
Show286's Avatar
3.5in. especially if your going to upgrade your turbo later
Old Apr 13, 2008 | 10:05 AM
paintballproam's Avatar
just throwing this out there, but how does the ets core compare to the buschur one?
Old Apr 13, 2008 | 10:07 AM
Billy@EnglishRacing's Avatar
3 inch, you will lose spool with a bigger fmic, The 3 inch is going to be the best choice up until about 525-550
Old Apr 17, 2008 | 01:23 PM
ETS Michael's Avatar
The 3" is the perfect choice for up to 500whp but you won't lose spool going to a larger intercooler as that is a bit of a misconception. The larger cores will actually outflow the 3" which is why they are beneficial when airflow exceeds 500whp worth. The bigger intercoolers will flow even better than the smaller core, though that extra flow is not necessary for no restriction at the lower power levels
Tmo
Old Apr 17, 2008 | 01:39 PM
mplspilot's Avatar
3.5 cause bigger is better. Everyone knows that!
Old Apr 17, 2008 | 05:00 PM
JDMCT9MR's Avatar
+1 on the 3" ETS FMIC.
Old Apr 17, 2008 | 06:48 PM
dbsears's Avatar
3.5in...there is no drawbacks besides being a hair more $$$. Like Tom said you won't lose spool between the two but have a higher threshold before heatsoak. Fitment is equally good on both.
Old Apr 18, 2008 | 08:00 PM
What do you guys think about the 4' fmic? Stock turbo with bolt ons. Im planning on going fp green but not until end of the year.
