Big cams little Turbo
Old Jan 11, 2010 | 04:37 PM
  #196
Jimbolution's Avatar
Kelford / GSC S2 they seem to be a kind of good investment... some people said that on a stock EVO IX the S2 didn't make losing bottom. But if i have a tune on my EVO VIII but with the stock turbo, did i will notice a big lost on bottom... (Bigger turbo is for later)
springs are necessary for the S2 but with EVO with not a lot of mods... did we need the retainers too or we can pu it like a year after when upgrade turbo ?
Old Jan 11, 2010 | 06:07 PM
  #197
JohnBradley's Avatar
Originally Posted by Turbojunkie
So the s2r's ( 278/274) are no longer an option? Im curious if i should switch to a different cam from the comps.
S2Rs are secret sauce sitting in a box by my desk. The 278/274 combo were normal S2s and apparently no longer available. The S2R is my name for them, they are just some custom spears that Greg whipped up for me
Old Jan 11, 2010 | 06:12 PM
  #198
Originally Posted by penthouse
stock cams are better than brian crower? really
Yes, stock CAMS ARE WAY BETTER THAN Brian Crower 272s. Dyno sheet for proof:
BC272 is the 332whp, S2s are the 356. Same day we dyno'd that car with the BC's every stock cam IX made 340+ with the same mods. Dont look at peak boost which in this case is torque, look at the boost plot versus peak power and you'll see the S2s made more with less.
Originally Posted by Kracka
In my opinion yes. The BC's will gain you a little power, but you will need to degree them with an adjustable cam gear and even then won't give you nearly the gains as a "good" cam. If you're going to go through the effort of installing cams (or paying to have it done), you might as well spend a little extra and actually get a proper camshaft.
I dont think cam gears will help them, they arent worth putting in a IX period. I agree totally about saving and paying for the right cams to begin with.
so what do u recommend kracka? gsc s2 or kelford 280 for my setup. Do i also need to install cam gear with these cams? thanks
Radically different cams, the S2s are 274/274 and the Kelford D cams are 280/282.
Jim, I didnt notice too much of a drop in low end on the VIIIs we do with the S2s. They seem to be very responsive despite their size.
Old Jan 12, 2010 | 05:33 AM
  #199
excellent... you have a new fan of GSC S2... the choice is made... we'll just wait to buy a pair... but im just asking myself if we got to put the retainer too when we put them??? ... i know for the spring...
that's the retainer making the cams kit $$$
Old Jan 12, 2010 | 08:59 AM
  #200
scheides's Avatar
EvoM Moderator
Just do the S2's and GSC's basic spring kit, 5039 IIRC. Stock seats and retainers are dandy for *most* evos.
Old Jan 12, 2010 | 06:37 PM
  #201
Uncorrected sheet for the S2 vs BC to further illustrate-
Old Jan 12, 2010 | 06:43 PM
  #202
bbyevo8u's Avatar
what do you mean by *most* evos are ok with oem retainers?
Old Jan 12, 2010 | 08:07 PM
  #203
Kracka's Avatar
That all depends on your setup and what springs you're planning on running. I think what Scheides is trying to say is that the standard beehive springs for use with the stock seats/retainers are adequate for the majority of setups.
Old Jan 13, 2010 | 12:29 AM
  #204
penthouse's Avatar
wow johh b. that s2 gain like 30whp, 30 wtg up on top vs brian crower. Nice, iam defitely be swithing out cams this summer.
Old Jan 13, 2010 | 07:28 AM
  #205
94AWDcoupe's Avatar
while this may be true it may be that the setup wasnt ready for bigger cams.
many years ago I upgraded from HKS 272 to crower 280s. The upgrade was like installing cams for first time. car picked up 4mph at track with just cam change. this was on a stroker with 25g turbo.
a couple years ago I had a car with 264 cams and a 2.3/20g. I heard rave reviews about gsc cams so I bought some gsc 280s for the car. that upgrade day was the most dissapointing to date. car lost power everywhere. the losses down low were like 600rpm spool loss and 50tq loss. setup simply was not ready for some big cams.
Old Jan 13, 2010 | 07:31 AM
  #206
penthouse's Avatar
so u saying the crower 280 is better than the gsc 280?
Old Jan 13, 2010 | 07:40 AM
  #207
dbsears's Avatar
How do S2's idle on a IX? I have yet to hear a set up close. Only heard S1's which seem to suite me but power wise don't seem to justify the cost for me atleast. I don't prefer big lope and sitting in the car I don't particulary want my car and dash to shake as I have enough rattles with 12kg coilovers. Any input on this?
Old May 7, 2010 | 08:15 PM
  #208
kaj's Avatar
kaj
K. Made it to page 10 before my eyes fell out.
This single thread alone, by the way, has prompted me to turn off sigs. LOL.
Anyway, my car sees 2-3 track days (buttonwillow, usually), a couple auto-xs, and an occasional weekend fun drive. My mods are in my sig. I plan to never port the head. Plan to keep stock rev limit so as not to require springs/retainers.
On my work bench are a set of Tomei PonCams and Cosworth M2s.
Advice? Are the M2s more than I need?
Old May 7, 2010 | 08:17 PM
  #209
kaj's Avatar
kaj
PS: WTF is a "smim"?
Old May 7, 2010 | 08:29 PM
  #210
BLKCarbonEVO's Avatar
The old style Magnus Sheet Metal Intake Manifold (SMIM)
Mikey
